Opening XText Editor Programmatically [message #640830] |
Tue, 23 November 2010 05:24  |
Hi All,
I want to open XText Editor Programmatically. I am using this command to open it but it give error can any one help me?
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().openEditor(new StringEditorInput(""),editorId, true);
it gives following ERROR!
java.lang.IllegalArgumentException: Couldn't create EMF Resource for input com.eadsiw.modelicaml.tabbedproperties.utils.StringEditorInp ut @dc7d5f
at org.eclipse.xtext.ui.editor.model.ResourceForIEditorInputFac tory.createResource(ResourceForIEditorInputFactory.java:56)
at org.eclipse.xtext.ui.editor.model.XtextDocumentProvider.setD ocumentContent(XtextDocumentProvider.java:102)
at org.eclipse.ui.editors.text.StorageDocumentProvider.createDo cument(StorageDocumentProvider.java:229)
at org.eclipse.ui.editors.text.StorageDocumentProvider.createEl ementInfo(StorageDocumentProvider.java:261)
at org.eclipse.ui.editors.text.FileDocumentProvider.createEleme ntInfo(FileDocumentProvider.java:770)
at org.eclipse.xtext.ui.editor.model.XtextDocumentProvider.crea teElementInfo(XtextDocumentProvider.java:131)
at org.eclipse.ui.texteditor.AbstractDocumentProvider.connect(A bstractDocumentProvider.java:400)
at org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(Abst ractTextEditor.java:4056)
at org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(Status TextEditor.java:217)
at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetI nput(AbstractDecoratedTextEditor.java:1444)
at org.eclipse.ui.editors.text.TextEditor.doSetInput(TextEditor .java:169)
at org.eclipse.xtext.ui.editor.XtextEditor.doSetInput(XtextEdit or.java:149)
at org.eclipse.ui.texteditor.AbstractTextEditor$19.run(Abstract TextEditor.java:3043)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:372)
at org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:759)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:756)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2600)
at org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:3061)
at org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:3088)
at org.eclipse.xtext.ui.editor.XtextEditor.init(XtextEditor.jav a:169)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:798)
at org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:647)
at org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:289)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2863)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2768)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2760)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2711)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2707)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2691)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2682)
at com.eadsiw.modelicaml.tabbedproperties.sections.ModelicaCode Section.createControls(ModelicaCodeSection.java:104)
at org.eclipse.ui.views.properties.tabbed.TabContents$1.run(Tab Contents.java:109)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at org.eclipse.ui.views.properties.tabbed.TabContents.createCon trols(TabContents.java:112)
at org.eclipse.ui.views.properties.tabbed.TabbedPropertySheetPa ge$SelectionChangedListener.selectionChanged(TabbedPropertyS heetPage.java:206)
at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:162)
at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer .java:160)
at org.eclipse.jface.viewers.StructuredViewer.updateSelection(S tructuredViewer.java:2162)
at org.eclipse.jface.viewers.StructuredViewer.handleSelect(Stru cturedViewer.java:1190)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetSelected( StructuredViewer.java:1220)
at org.eclipse.jface.util.OpenStrategy.fireSelectionEvent(OpenS trategy.java:228)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.ja va:222)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:389)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:7 74)
at org.eclipse.ui.internal.views.properties.tabbed.view.TabbedP ropertyList.select(TabbedPropertyList.java:664)
at org.eclipse.ui.internal.views.properties.tabbed.view.TabbedP ropertyList$2.mouseUp(TabbedPropertyList.java:156)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:213)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3657)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 38)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:613)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
I tried to open ordinary Editors they are working fine but not XText waiting for your reply
/Dani
Re: Opening XText Editor Programmatically [message #1051099 is a reply to message #1042819] |
Sun, 28 April 2013 03:38  |
On 04/17/2013 01:16 AM, Roza Ghamari wrote:
> I have a related question. I'd like to use the Xtext editor, but I am
> not creating any IProject or IWorkspace in my application. Does this
> mean that I cannot get the Xtext editor? Is there any way to mock
> iproject or create a dummy iproject?
> Thanks for your help in advance.
Hi there
I once did that by creating automatically a project in the workspace
(hidden) and then create a file in that project with some specific
contents and then open the Xtext editor on that file.
The scenario was using Xtext editors in the Bpel designer.
That was the solution I found at that time (see this old project
http://code.google.com/a/eclipselabs.org/p/bpel-xtext/).
Since Xtext introduced the embedded xtext editor, I switched to that
solution (embeddable Xtext editors in the bpel designer is going to be
part of the bpel designer, it's already in the git repo of bpel project,
see the discussion here
http://dev.eclipse.org/mhonarc/lists/bpel-dev/msg01550.html
hope this helps
Lorenzo
HOME: http://www.lorenzobettini.it
FUDForum. Page generated in 0.03672 seconds
