Eclipse plugin [message #1049992] |
Fri, 26 April 2013 10:57  |
Hi everybody!
I'm trying to write eclipse plugin. In the latest version my project i used SWT/JFace table but now i need use NatTable.Well..
I've got this error
An error has occurred. See error log for more details.
org/eclipse/nebula/widgets/nattable/data/IDataProvider
I am just trying to execute this code
IWorkbenchPage page = PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage();
Shell shell = new Shell(Display.getCurrent());
shell.setLayout(new FillLayout());
shell.setSize(800, 400);
shell.setText("NatTable1");
new CreateNatTable(shell);
shell.open();
while (!shell.isDisposed()) {
if (!Display.getCurrent().readAndDispatch()) {
Display.getCurrent().sleep();
shell.dispose();
Display.getCurrent().dispose();
Re: Eclipse plugin [message #1050018 is a reply to message #1049999] |
Fri, 26 April 2013 11:27   |
Thanks for answering
..well CreateNatTable it is simple class with this constructor
public class CreateNatTable {
public static final String ID = "com.project.CreateNatTable";
private Composite parent = null;
private NatTable natTable = null;
public CreateNatTable(Composite parent) {
this.parent = parent;
DummyBodyDataProvider bodyDataProvider = new DummyBodyDataProvider(2, 10);
SelectionLayer selectionLayer = new SelectionLayer(new DataLayer(bodyDataProvider));
DataLayer colDataLayer = new DataLayer(new DummyColumnHeaderDataProvider(bodyDataProvider));
ILayer columnHeaderLayer = new ColumnHeaderLayer(colDataLayer, selectionLayer, selectionLayer);
CompositeLayer compositeLayer = new CompositeLayer(1, 2);
compositeLayer.setChildLayer(GridRegion.COLUMN_HEADER, columnHeaderLayer, 0, 0);
compositeLayer.setChildLayer(GridRegion.BODY, selectionLayer, 0, 1);
natTable = new NatTable(this.parent, compositeLayer, false);
Oh i see..this method SelectionLayer selectionLayer = new SelectionLayer(new DataLayer(bodyDataProvider)); trying to get datas and crushing.
I just want to run simple example without any datas on columns and raws.
Re: Eclipse plugin [message #1050045 is a reply to message #1050033] |
Fri, 26 April 2013 12:06  |
This is a classpath issue. Make sure that your bundle manifests have the right dependencies in them. I'm guessing you forgot to add the nattable dependencies somewhere.
Edwin
FUDForum. Page generated in 0.03583 seconds
