Home » Language IDEs » Java Development Tools (JDT) » Memory leaks in Eclipse?
Memory leaks in Eclipse? [message #104338] Tue, 14 October 2003 08:35 Go to next message
I have been using Eclipse for quite some time now on windows XP. After a
couple of hours of work with 2.2.1 Eclipse runs out of memory, and
requires a restart.
Today I installed 3.0 RC4 hoping that perhaps this memory leak problem has
been addressed, however it seems that it is only exasperated. I get out of
memory errors every 15 minutes now.
I can see this in the log file:
!SESSION Oct 14, 2003 14:27:22.214
java.version=1.4.1_02
Command-line arguments: -os win32 -ws win32 -arch x86 -install
file:C:/Program Files/eclipse/
!ENTRY org.eclipse.ui 4 4 Oct 14, 2003 14:27:22.214
!MESSAGE Exception in org.eclipse.ui.actions.BuildAction. run:
java.lang.OutOfMemoryError
!ENTRY org.eclipse.ui 4 4 Oct 14, 2003 14:27:22.229
!STACK 0
Is this a known issue? Is anything being done about it?
Yoav
Re: Memory leaks in Eclipse? [message #104359 is a reply to message #104338] Tue, 14 October 2003 09:04 Go to previous messageGo to next message
Originally posted by: hcs33.egon.gyaloglo.hu
1. Did you use -vmargs to specify the max amount of memory Eclipse uses? If
you don't, the default settings are too low for Eclipse (64Mb). Try to use
i.e. 'eclipse -vmargs -Xmx256M'.
2. If you run ant scripts regularly you should run ant in a separate vm (it
is a new 3.0 feature).
HTH,
Csaba
"Yoav Frandzel" <yoav.frandzel@intel.com> wrote in message
news:bmgqin$bij$1@eclipse.org...
> requires a restart.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 0
> Yoav
Re: Memory leaks in Eclipse? [message #104364 is a reply to message #104338] Tue, 14 October 2003 10:38 Go to previous messageGo to next message
Yoav Frandzel wrote:
> requires a restart.
I have also noticed that if you run junit tests or sample apps inside
eclipse, even once they are terminated they hang around. You can delete
these processes by looking in the debugging view in the 'debug' panle
and right clicking - there you get an option to remove terminated processes.
Hope this helps.
Chris
Re: Memory leaks in Eclipse? [message #104418 is a reply to message #104338] Tue, 14 October 2003 11:32 Go to previous messageGo to next message
We had an issue where it helped to delete the .metadata folder which was
>120MB.
> requires a restart.
> !STACK 0
> Yoav
Re: Memory leaks in Eclipse? [message #104903 is a reply to message #104338] Wed, 15 October 2003 02:23 Go to previous message
Thanks for your suggestions. The first one seems to be working.
> requires a restart.
> !STACK 0
> Yoav
Previous Topic:How do I get the debugger not to step into system classes?
Next Topic:code formatting: changing the use of fully qualified names into imports
Current Time: Sat Jul 19 22:05:57 EDT 2025
Powered by FUDForum. Page generated in 0.04908 seconds
