Home » Archived » Hudson » Hudson with HTTPS
Hudson with HTTPS [message #1047720] Tue, 23 April 2013 11:05 Go to next message
Hey guys,
Maybe a stupid question but I googled a lot and did not find a way to make HTTPS works with Hudson.
I did create my certificate using Step 1 to 4 from
http://www.akadia.com/services/ssh_test_certificate.html
and following this :
http://wiki.hudson-ci.org/display/HUDSON/Starting+and+Accessing+Hudson
Then, I added these start parameters in the service properties tab (Under Windows) :
hudson.exe --httpPort=-1 --httpsPort=19443 --httpsKeyStore=winstone.ks --httpsKeyStorePassword=....
But it does not seems as Hudson is taking the parameters (still working on port 8080).
I also added in the <arguments> field of the hudson.xml but it does not seem to take it in account. Any suggestions?
[Updated on: Tue, 23 April 2013 11:07] by Moderator
Re: Hudson with HTTPS [message #1047729 is a reply to message #1047720] Tue, 23 April 2013 11:13 Go to previous messageGo to next message
Finally, it worked correctly. I add an issue with the path of the winstone.ks.
Parameters should be added in the hudson.xml as :
<executable>java</executable>
<arguments>-Xrs -Xmx512m -XX:MaxPermSize=256m -Dhudson.lifecycle=hudson.lifecycle.WindowsServiceLifecycle -jar "%BASE%\hudson.war" --httpPort=-1 --httpsPort=19443 --httpsKeyStore=C:/Users/hudsonUser/.hudson/winstone.ks --httpsKeyStorePassword=....</arguments>
Hope this thread will be useful for other people who wants to configure it under HTTPS. Good luck
Re: Hudson with HTTPS [message #1047787 is a reply to message #1047729] Tue, 23 April 2013 12:43 Go to previous messageGo to next message
Frederic, thanks for the notes. I believe this is for Hudson 2.x not for 3.x right?
Re: Hudson with HTTPS [message #1498052 is a reply to message #1047787] Thu, 04 December 2014 01:28 Go to previous messageGo to next message
Hi Prakash,
could you please give me the steps i need to follow for hudson with HTTPS for ver 3.2.
hudson 3.2 ,apache tomcat 7.0.26
Mahesh
Re: Hudson with HTTPS [message #1506389 is a reply to message #1498052] Wed, 10 December 2014 15:37 Go to previous message
Since you are using Tomcat you have to follow Tomcat documentation to setup HTTPS. Try this link http://tomcat.apache.org/tomcat-7.0-doc/ssl-howto.html
Previous Topic:"Build when Maven dependencies have been updated" uses transitive dependencies?
Next Topic:GIT - clean checkout fails
Current Time: Sat Jul 19 21:13:04 EDT 2025
Powered by FUDForum. Page generated in 0.03923 seconds
