Home » Modeling » EMF » EMF Edit - can additional operations happen when a command happens?
EMF Edit - can additional operations happen when a command happens? [message #1046945] |
Mon, 22 April 2013 11:29  |
I have a form-based editor, backed by EMF using the EMF Edit databindings. The editor's dirty state and undo/redo are all linked into the EditingDomain's dirty flag - all good.
The editor modifies a number of files, which aren't linked in an EMF-aware manner. For example, in one file a reference is made to a particular object name, which is also referred to in another file.
I'd like it to be the case that, when I modify the object name in a Text box, it changes in both places.
Is the best way of doing this to have two bindings registered, both with the Text as target but different EMFEdit observables in the background? Or is there another way, whereby changing the value in the binding also triggers a change in the other place? I would use Adapters, but I'm not sure they fit into the EditingDomain's view of things - is that correct?
Re: EMF Edit - can additional operations happen when a command happens? [message #1046972 is a reply to message #1046945] |
Mon, 22 April 2013 12:05   |
Ben,
Comments below.
> EMF-aware manner.
The editor modifying files seems bad in and of itself. One generally
expects and editor to make to changes to the underlying storage except
when you save. So if you close a dirty editor, any changes you made
should have no impact...
So you're really modifying other files and "saving" those changes?
> background?
Probably, if it's all just in-memory changes.
> that correct?
All the views supported directly by EMF.Edit using adapters so that's
fine too.
Re: EMF Edit - can additional operations happen when a command happens? [message #1047021 is a reply to message #1046972] |
Mon, 22 April 2013 13:27   |
Hi Ed,
Thanks for your speedy response. Comments below.
> EMF-aware manner.
Sorry, perhaps I wasn't clear. To clarify, the editor only makes changes to the files when a save is requested. The point I was trying to highlight was that the editor takes input from, and will save to, a number of files - much like the PDE Manifest Editor, which uses MANIFEST.MF, plugin.xml and build.properties.
Quote:> For example, in one file a reference is made to a particular object
Err... maybe?
Quote:> Is the best way of doing this to have two bindings registered, both
> background?
> that correct?
fine too.
I will try to find some solution that involves either a number of bindings or adapters. I just want to ensure that the additional changes caused by that change are seen by the EditingDomain, and are added to the same step on the command stack.
Current Time: Sat Jul 19 14:30:25 EDT 2025
Powered by FUDForum. Page generated in 0.06564 seconds
