Home » Modeling » TMF (Xtext) » AudoEditStrategy with context?
AudoEditStrategy with context? [message #1047184] Mon, 22 April 2013 18:30 Go to next message
Greetings everyone.
Does anyone know how I would go about implementing an AutoEditStrategy only in certain places of my model? The IAutoEditStrategy#customizeDocumentCommand only has an IDocument and DocumentCommand accessible, and no information or context about where I am in the model.
I would like to be able to take a list of items on a line like this:
containerName { item1, item2, item3, item4 }
And with each press of the [ENTER] button anywhere inside the brackets, I would like my AutoEditStrategy to insert a backslash indicating to my (external) compiler that the line has wrapped, like this:
containerName {\
  item1,\
  item2,\
  item3,\
  item4\
The key is, that the backslash should only be inserted if [ENTER] is pressed inside of the brackets. It should not insert a backslash outside the scope of the container.
Any ideas?
Re: AudoEditStrategy with context? [message #1047259 is a reply to message #1047184] Mon, 22 April 2013 21:24 Go to previous messageGo to next message
On 2013-23-04 24:30, Brad Riching wrote:
> Greetings everyone.
> am in the model.
> containerName {\
> item1,\
> item2,\
> item3,\
> item4\
> Any ideas?
IIRC the auto edit is tied to regions in the text (i.e. inside strings,
comments etc.), but I don't remember exactly how. Think you need to read
the source for auto edits to figure it out.
- henrik
Re: AudoEditStrategy with context? [message #1047719 is a reply to message #1047259] Tue, 23 April 2013 11:01 Go to previous message
Thanks Henrik, I will give it a try and post my results if I come up with anything.
Previous Topic:JFace data binding between swt to Xtext model
Next Topic:cross-file references does not work after update (missing .classpath file)
Current Time: Sat Jul 19 22:49:57 EDT 2025
Powered by FUDForum. Page generated in 0.05063 seconds
