Home » Eclipse Projects » Equinox » Problem running the Equinox P2 Getting Started guide
Problem running the Equinox P2 Getting Started guide [message #104643] Fri, 01 February 2008 17:08 Go to next message
Hi all,
Apologies for this probably stupid newbie question, but I was following
the steps of the Equinox P2 getting started guide:
http://wiki.eclipse.org/Equinox_p2_Getting_Started
When I'm adding the suggested new repository from the following URL
http://download.eclipse.org/eclipse/testUpdates/ I'm getting the
following exception (copied from the .log file):
org.eclipse.equinox.p2.core.ProvisionException: Unable to add repository
at
org.eclipse.equinox.p2.ui.operations.ProvisioningUtil.addMet adataRepository(ProvisioningUtil.java:46)
at
org.eclipse.equinox.p2.ui.operations.AddMetadataRepositoryOp eration.doExecute(AddMetadataRepositoryOperation.java:33)
at
org.eclipse.equinox.p2.ui.operations.UndoableProvisioningOpe ration.execute(UndoableProvisioningOperation.java:78)
at
org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:511)
at
org.eclipse.equinox.p2.ui.ProvisioningOperationRunner$1.run( ProvisioningOperationRunner.java:50)
I'm using M4 on Windows.
Anyone any idea?
Thanks in advance,
David
Re: Problem running the Equinox P2 Getting Started guide [message #104804 is a reply to message #104643] Wed, 06 February 2008 12:53 Go to previous messageGo to next message
Originally posted by: l2.miegel.org
I am getting the same error, on both my home and work machine. The site does not appear to be down, so I suspect the team is just too busy to keep the test site in sync with all the changes going on.
Nigel
Re: Problem running the Equinox P2 Getting Started guide [message #104815 is a reply to message #104804] Wed, 06 February 2008 15:43 Go to previous message
There is indeed a lot of flux right now as we're leeding up to M5 with
slight changes in metadata here and there.
If you want to try an SDK install you can use the I20082006-0010 build as I
can confirm that works.
"Nigel Westbury" <l2@miegel.org> wrote in message
news:21648978.11821202320447313.JavaMail.root@cp1.dzone.com...
> Nigel
Previous Topic:Equinox Embedded within WAS 6.1 in Real Live
Next Topic:classpath cycle with pde build
Current Time: Sat Jul 19 21:11:45 EDT 2025
Powered by FUDForum. Page generated in 0.03504 seconds
