Home » Archived » M2M (model-to-model transformation) » [ATL]The `IN' and 'OUT' in a code line.
[ATL]The `IN' and 'OUT' in a code line. [message #104595] Wed, 06 May 2009 05:07 Go to next message
The following two lines are respectively for loading the input
model and creating the output model. I have no idea of what the "IN" and
"OUT" mean: are they corresponding to the model variables in the ATL
files?
Thanks.
Michael.
ASMEMFModel jwtInputModel = (ASMEMFModel) modelHandler.loadModel("IN",
jwtMetamodel, URI.createFileURI(inFilePath));
ASMEMFModel bpmnOutputModel = (ASMEMFModel)
modelHandler.newModel("OUT",
URI.createFileURI(outFilePath).toFileString(), bpmnMetamodel);
Re: [ATL]The `IN' and 'OUT' in a code line. [message #104610 is a reply to message #104595] Wed, 06 May 2009 05:39 Go to previous messageGo to next message
Michael a écrit :
> files?
Exactly.
William
> Thanks.
> Michael.
Re: [ATL]The `IN' and 'OUT' in a code line. [message #104619 is a reply to message #104595] Wed, 06 May 2009 06:08 Go to previous messageGo to next message
Originally posted by: mickael.istria.openwide.fr
Michael a écrit :
> files?
> Thanks.
> Michael.
Yes, it is!
You can find the ATL transformation for this example here ->
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jwt/tra nsformations/jwt-transformation-bpmn/src/org/eclipse/jwt/tra nsformations/bpmn/internal/resources/Jwt2BpmnAllInPool.atl?r evision=1.1&root=Technology_Project&view=markup
By the way, please note that a few modification occurred on this example
code to follow ATLv3 API.
Checkout the jwt-transformations-bpmn folder for a full example using ATLv3.
Mickael
Re: [ATL]The `IN' and 'OUT' in a code line. [message #104632 is a reply to message #104619] Wed, 06 May 2009 08:12 Go to previous messageGo to next message
Mickael Istria wrote:
> Michael a écrit :
>> Hi,
>> and "OUT" mean: are they corresponding to the model variables in the
>> ATL files?
>> Thanks.
>> Michael.
> Yes, it is!
> ATLv3.
> Regards,
> Mickael
Thanks for your help. I tried to check out the example code from CVS,
but I could not find it. Please give me some hint. Thanks.
Re: [ATL]The `IN' and 'OUT' in a code line. [message #104644 is a reply to message #104632] Wed, 06 May 2009 08:54 Go to previous messageGo to next message
>> Michael a écrit :
>>> Hi,
>>> ATL files?
>>> Thanks.
>>> Michael.
>>> modelHandler.loadModel("IN", jwtMetamodel,
>> Yes, it is!
>> example code to follow ATLv3 API.
>> ATLv3.
>> Regards,
>> Mickael
Sure
Protocol: pserver
Server: dev.eclipse.org
user: anonymous
Root: /cvsroot/technology
module: org.eclipse.jwt/transformations/jwt-trasformation-bpmn
cvs -d :pserver:anonymous@dev.eclipse.org:/cvsroot/technology/ checkout
org.eclipse.jwt/transformations/jwt-transformation-bpmn
HTH
Mickael
Re: [ATL]The `IN' and 'OUT' in a code line. [message #104658 is a reply to message #104644] Wed, 06 May 2009 09:11 Go to previous messageGo to next message
>>> Michael a écrit :
>>>> Hi,
>>>> the ATL files?
>>>> Thanks.
>>>> Michael.
>>> Yes, it is!
>>> ATLv3.
>>> Regards,
>>> Mickael
> Sure
> Protocol: pserver
> user: anonymous
> HTH
> Mickael
Hi, Mickael:
Thanks for your warm-hearted and timely help.
I have tried this example with my own metamoel and models. It seems work
fine but the output model is always empty; when extracted to xml file,
it reports null-pointer exception. The metamodels, input model and
tranformation file are very simple and surely correct (I have run this
transformation successfully in an ATL project). I consider that this may
be due to wrong library. Would you please tell me what library I should
use and what version they are.
Thanks.
Michael.
Re: [ATL]The `IN' and 'OUT' in a code line. [message #104671 is a reply to message #104658] Wed, 06 May 2009 09:44 Go to previous message
>>>> Michael a écrit :
>>>>> Hi,
>>>>> "IN" and "OUT" mean: are they corresponding to the model variables
>>>>> in the ATL files?
>>>>> Thanks.
>>>>> Michael.
>>>> Yes, it is!
>>>> using ATLv3.
>>>> Regards,
>>>> Mickael
>> Sure
>> Protocol: pserver
>> user: anonymous
>> checkout org.eclipse.jwt/transformations/jwt-transformation-bpmn
>> HTH
>> Mickael
> Hi, Mickael:
> Thanks.
> Michael.
Dependencies and versions are explicitly set in the META-INF/MANIFEST.MF.
The NPE may be related to wrong resources path or something like that,
try running this code in debug mode, and you'll hopefully get more
details...
HTH
Mickael
Previous Topic:[ATL] Compatibility between ATL2 and ATL3?
Next Topic:[QVTO] What's new in 2.0.0?
Current Time: Sat Jul 19 15:19:37 EDT 2025
Powered by FUDForum. Page generated in 0.04613 seconds
