Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Registration timeout after 5000 milliseconds
Registration timeout after 5000 milliseconds [message #104234] Wed, 05 December 2007 07:40 Go to next message
Originally posted by: mascht.hotmail.com
Hi Eike,
If I try to connect to CDO Server by using CDO Sessions View I get an
"Registration timeout after 5000 milliseconds" Error.
My Settings are:
Server Description: tcp://localhost:2036
Repository Name: repo1
I'am running the Preinstalled CDO Server Environment using Derby DB.
(http://wiki.eclipse.org/images/9/92/Cdo-server.zip)
regards,
Martin
org.eclipse.net4j.util.concurrent.TimeoutRuntimeException: Registration
at
org.eclipse.net4j.internal.tcp.ControlChannel.registerChanne l(ControlChannel.java:94)
at
org.eclipse.net4j.internal.tcp.TCPConnector.registerChannelW ithPeer(TCPConnector.java:264)
at org.eclipse.internal.net4j.Connector.openChannel(Connector.j ava:400)
at org.eclipse.internal.net4j.Connector.openChannel(Connector.j ava:387)
at
org.eclipse.emf.internal.cdo.CDOSessionImpl.doActivate(CDOSe ssionImpl.java:596)
at
org.eclipse.net4j.internal.util.lifecycle.Lifecycle.activate (Lifecycle.java:52)
at
org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(Life cycleUtil.java:73)
at
org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(Life cycleUtil.java:61)
at
org.eclipse.net4j.internal.util.container.ManagedContainer.g etElement(ManagedContainer.java:260)
at
org.eclipse.emf.cdo.internal.ui.actions.OpenSessionAction.do Run(OpenSessionAction.java:60)
at
org.eclipse.net4j.util.ui.actions.LongRunningAction$1.run(Lo ngRunningAction.java:166)
at
org.eclipse.net4j.util.om.monitor.MonitoredJob.run(Monitored Job.java:48)
Re: Registration timeout after 5000 milliseconds [message #104255 is a reply to message #104234] Wed, 05 December 2007 07:43 Go to previous messageGo to next message
Martin,
Please use [CDO] in the subject line since the newsgroup is shared by a
large number of components.
Eike is on vacation until Dec 12, so hopefully someone else will be able
to help...
Martin Claus wrote:
> Hi Eike,
> My Settings are:
> regards,
> Martin
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Re: Registration timeout after 5000 milliseconds [message #104493 is a reply to message #104234] Wed, 12 December 2007 07:11 Go to previous message
Originally posted by: stepper.sympedia.de
Hi Martin,
Your problem most probably results from using a newer client with this
quite old server pre-installation. Since it's on the wiki it always gets
out-dated rather qickly. The best approach is to generate a new server
installation from the file
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.emf/org .eclipse.emf.cdo/features/org.eclipse.emf.cdo.server.product /CDOServer.product?root=Modeling_Project&view=log
.. When you checked out all the sources via All.psf (
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.emf/org .eclipse.emf.cdo/develop/psf/pserver/All.psf?root=Modeling_P roject&view=co
) it is found in the org.eclipse.emf.cdo.server.product feature
If the problem still persists be so kind to open a new Bugzilla.
Eike Stepper
http://wiki.eclipse.org/?title=CDO
http://wiki.eclipse.org/?title=Net4j
Martin Claus schrieb:
> Hi Eike,
> My Settings are:
> regards,
> Martin
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Registration timeout after 5000 milliseconds [message #612747 is a reply to message #104234] Wed, 05 December 2007 07:43 Go to previous message
Martin,
to help...
Martin Claus wrote:
> Hi Eike,
> My Settings are:
> regards,
> Martin
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Registration timeout after 5000 milliseconds [message #612789 is a reply to message #104234] Wed, 12 December 2007 07:11 Go to previous message
Hi Martin,
Eike Stepper
> Hi Eike,
> My Settings are:
> regards,
> Martin
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Previous Topic:Pattern EMF
Next Topic:[CDO][0.8.0] Release StoreReader
Current Time: Sat Jul 19 08:44:37 EDT 2025
Powered by FUDForum. Page generated in 0.07180 seconds
