Home » Modeling » QVT-OML » second mapping steals first one
second mapping steals first one [message #1043373] Wed, 17 April 2013 12:12 Go to next message
I want to transform a UML-Statechart into a Class diagramm:
modeltype UML uses "http://www.eclipse.org/uml2/4.0.0/UML";
transformation state2class(in stateM:UML,out classM:UML);
property curmainclass : UML::Class = null;
main()
stateM.objectsOfType(StateMachine)->map toPackage();
mapping StateMachine::toPackage() : UML::Package
name := self.name;
nestedPackage := self.region.map toPackage();
mapping Region::toPackage() : UML::Package
name := self.name;
var oberklasse = object Class {};
oberklasse.name := "State";
/*!1!*/
oberklasse.ownedOperation := self.transition.map transToOp();
ownedType += oberklasse;
curmainclass := oberklasse;
ownedType += self.subvertex.map toClass();
/* jeder Knoten wird in eine Klasse umgewandelt */
mapping Vertex::toClass() : UML::Class
name := self.name;
result.superClass += curmainclass;
/*!2!*/
result.ownedOperation += self.container.transition->select(t | t.target = self).map transToOp();
mapping Transition::transToOp() : UML::Operation
name := self.name;
In the output without /*!2!*/ the Class "State" has all the transitions as Operations.
Now /*!2!*/ generates Operations in the concrete State-classes, but there the operations in the Class "State" are missing.
Why ?
May a Mapping has a implicit relation and QVTo can generate only 1:1-Mappings ?
Problem with forEach / Re: second mapping steals first one / Resolve with new objects [message #1043381 is a reply to message #1043373] Wed, 17 April 2013 12:24 Go to previous messageGo to next message
Ok, only 1:1-Mapping is allowed.
Thus, I have to generate a new Object:
name := self.name;
//result.ownedOperation += self.container.transition->select(t | t.target = self).map transToOp();
var opset : Set(Operation);
self.container.transition->forEach(t | t.target = self)
var op = object Operation { name := t.name; }
result.ownedOperation += op; //!Syntaxerror
The problem is:
in the {}-Block after forEach the "result" is unknown.
An declared variable is not known in the {}-Block
How to write a new operation-Object forEach Transition in the concrete State-Class ?
(or may this an implementation-Problem ?)
Greetings from Ravensburg/Germany
Rudolf Weber
Re: second mapping steals first one [message #1043822 is a reply to message #1043373] Thu, 18 April 2013 02:59 Go to previous messageGo to next message
HI
QVTo generates on mapping for each distinct tuple of matching input
objects, so if your input tuple is a single object, you indeed get 1:1.
If you want 1:N you need to introduce an additional disambiguator to the
tuple so that QVTo understands that you do not want the 'multiple'
mappings unified. For instance you might add a count variable to the
mapping.
Ed Willink
On 17/04/2013 17:12, Rudolf Weber wrote:
> Hello,
> main()
> mapping StateMachine::toPackage() : UML::Package {
> name := self.name;
> name := self.name;
> /*!1!*/
> name := self.name;
> /*!2!*/
> name := self.name;
> Why ? May a Mapping has a implicit relation and QVTo can generate only
> 1:1-Mappings ?
Re: second mapping steals first one [message #1043902 is a reply to message #1043822] Thu, 18 April 2013 04:42 Go to previous messageGo to next message
mapping.
Is a "tuple" (source,result,parameter)-tuple in the internal mapping of a QVTo-Run ?
I have added a parameter and it works as expected:
main()
	name := self.name;
   name := self.name;
   oberklasse.ownedOperation := self.transition.map transToOp(1);
	name := self.name;
	result.ownedOperation += self.container.transition->select(t | t.target = self).map transToOp(2);
/* called twice, so a parameter is needed */
mapping Transition::transToOp(in dis : Integer ) : UML::Operation
	name := self.name;
General question for QvTo:
Ok, I have now transformed a statechart-model to a classmodel.
But the UML-Classmodel doesn't have the semantic to specify the operations.
(I can't see it in the UML2.4.1 Infrastructure/Superstructure)
(May in future an operation have a Action-Sequence as implementation)
Generate code from the generated classes lacks information.
QVto M2T like Acceleo
So Statechart -------> Classmodell ---> Code
seems not the practical way ?
M2T
Statechart -------------> Code
seems simpler and better.
Rudolf Weber
RE: Statecharts (was Re: second mapping steals first one) [message #1044065 is a reply to message #1043902] Thu, 18 April 2013 09:02 Go to previous message
Direct M2T is easier when it's easier, but increasingly hard as the
problem gets more complex. Often difficult to re-use.
Since neither Java nor C++ has any StateMachine concepts, you will have
to realize them using Classes and operations, so you could consider
An M2M from: OO-with-states to OO-without-states
so that you can re-use an existing M2T for OO-without-states to code.
The M2M can be OO implementation language neutral and so re-useable.
If your target code is Java, then EMF code gen is viable for the
structure and OCL code gen for the behaviour.
Ed Willink
> operations.
> So Statechart -------> Classmodell ---> Code seems not the practical
> way ?
> M2T
> Regards Rudolf Weber
Previous Topic:Re: Mapping in/output programmatically
Next Topic:How I get the order of events covered on UML lifeline?
Current Time: Sat Jul 19 14:20:44 EDT 2025
Powered by FUDForum. Page generated in 0.08626 seconds
