Home » Modeling » ATL » UM2L to UML2: don't want to transform certain Generalizations and Associations
UM2L to UML2: don't want to transform certain Generalizations and Associations [message #1043195] |
Wed, 17 April 2013 08:05  |
Hi everyone,
I'm doing an UML2 to UML2 transformation and I'm running into a bit of trouble.
I only transform certain stereotyped classes, so then when I transform the generalizatios, associations, and other kind of relationships there are many of them that are just empty when transformed, since the objects they were referencing were not transformed.
How could I filter this?
I tried it this way:
rule generalization {
from
gen: UML2!Generalization (
not gen.oclIsUndefined() and gen.shouldBeCreated()
and not gen.general.oclIsUndefined()
to
trg: UML2!Generalization (
general <- gen.general -> debug('Generalization')
but it doesn't work, I'm guessing since general is actually defined, just defined on the wrong model.
So I was thinking there maybe is some way to check whether the element is still referencing another element from the Input transformation, in which case it wouldn't get transformed.
Thanks in advance, hope someone knows how to solve this,
regards,
Javier
Re: UM2L to UML2: don't want to transform certain Generalizations and Associations [message #1043869 is a reply to message #1043245] |
Thu, 18 April 2013 04:05   |
Hi Hugo,
the hasStereotype helper doesn't seem to work for me, it said that no such operation existed, so I used this instead:
not gen.refImmediateComposite().getAppliedStereotypes().isEmpty()
and not gen.general.refImmediateComposite().getAppliedStereotypes().isEmpty()
And it doesn't work as intended, if I use only the first line I get to skip a few generalizations, which is nice, but still the ones that exist inside a stereotyped class sometimes point to a class that isn't transformed, so I added that second line and what happens is that no generalizations are created, so I guess I'm probably doing something wrong but I can't seem to thin of a way to fix it.
Now I have a very similar problem but on Associations and Dependencies, I have these rules:
rule Association {
from
ua: UML2!Association (
ua.oclIsTypeOf(UML2!Association) and not ua.oclIsUndefined()
to
ma: UML2!Association (
name <- ua.name,
isAbstract <- ua.isAbstract,
generalization <- ua.generalization,
memberEnd <- ua.memberEnd,
ownedEnd <- ua.ownedEnd
rule Dependency {
from
ud: UML2!Dependency (
not ud.oclIsUndefined()
and ud.oclIsTypeOf(UML2!Dependency)
to
mi: UML2!Dependency (
supplier <- ud.supplier,
client <- ud.client,
name <- ud.name
So the thing is that when transformed, some of the memberEnd, ownedEnd, Supplier or client are not transformed, therefore the association/dependency shouldn't be transformed either, but I don' quite know how to do to filter it. Do you have any ideas? I tried some things but nothing seemed to work.
I'm checking the refining mode and it seems interesting, but it seems like though it might solve some of my problems it might cause some new ones, so I'm not completely sure that it would be a good choice to move my code to refining mode, but I'll do some further tests.
Thanks a lot for your help!
[Updated on: Thu, 18 April 2013 04:26] by Moderator
Re: UM2L to UML2: don't want to transform certain Generalizations and Associations [message #1044690 is a reply to message #1044084] |
Fri, 19 April 2013 04:02   |
Ok I didn't know that about the root element.
I also don't know why I called getClass, sometimes I overcomplicate things.
This helper is used for many things, for instance for a Parameter. Now the as I see it the Parameter is contained inside of an Operation, which is itself contained inside of a Class, therefore I thought it would be necessary to use recursivity here, to check if the parameter was inside a stereotyped class. Is there an easier way to check this? As otherwise I was getting some parameters transformed that didn't have an owner (the operation wasn't transformed) so I thought of this way to solve that problem, but any help is welcome.
So I still can't seem to be able to filter these elements (Association, Dependency..), since this helper still doesn't work, I tried some other ideas but nothing seems to work properly.
Thanks a lot for your input, I still need to learn a lot about ATL and I need all the help I can get!
Javier
Re: UM2L to UML2: don't want to transform certain Generalizations and Associations [message #1047468 is a reply to message #1043195] |
Tue, 23 April 2013 04:48   |
I finally got it done like this:
rule Association {
from
to
name <- ua.name -> debug('Association'),
ownedEnd <- ua.ownedEnd,
ownedComment <- ua.ownedComment
do{
if (not ma.memberEnd.testSet(2))
then ma.destroy()
else
false
endif;
I had to use the do block, which I don't really like, but it's the only possible solution I found.
Also in the if clause it forces me to write the else part, is there a way to avoid this? I just wrote "false" and it has no effect but it'd be nicer if I could delete that.
The testSet() method just tests the size of the memberEnd set, so when it's smaller than it should then it gets destroyed.
Let me know if you know of a better way to do this.
Re: UM2L to UML2: don't want to transform certain Generalizations and Associations [message #1049722 is a reply to message #1048265] |
Fri, 26 April 2013 03:36  |
Hi Sylvain, I tried that solution before but it doesn't work.
The thing is, the association in the input model is good, it has its "memberEnd" feature properly set, but since some of those elements belonging to the member end property don't get transformed, once the association is transformed the association gets transformed with one or none elements in the memberEnd property, so that's why I ended up doing it this way, since if I check on the input model it will tell me that it everything's fine. I don't know if it is supposed to work this way or if it should notice that the elements aren't transformed, but anyways the thing is that if I try it the way you said it doesn't seem to work.
Thanks a lot and any other advice would be appreciated!
Current Time: Sun Jul 20 09:32:58 EDT 2025
Powered by FUDForum. Page generated in 0.05924 seconds
