Home » Eclipse Projects » Eclipse Platform » Unable to read workbench state (Unable to read workbench state , workbench UI layout will be reset.)
Unable to read workbench state [message #1043167] Wed, 17 April 2013 07:16
I am getting a error "Unable to read workbench state, workbench UI layout will be reset." after taking a update for my RCP plugins.
I tried looking into the .log file. But i am not able to understand the problem. It seems some registries are missing.
Here is the .log content.
!ENTRY org.eclipse.ui.workbench 4 2 2013-04-17 15:44:29.145
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
!STACK 0
org.eclipse.core.runtime.InvalidRegistryObjectException: Invalid registry object
at org.eclipse.core.internal.registry.RegistryObjectManager.basicGetObject(RegistryObjectManager.java:272)
at org.eclipse.core.internal.registry.RegistryObjectManager.getObject(RegistryObjectManager.java:262)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.getConfigurationElement(ConfigurationElementHandle.java:26)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.getChildren(ConfigurationElementHandle.java:46)
at org.eclipse.ui.internal.menus.MenuAdditionCacheEntry.createContributionItems(MenuAdditionCacheEntry.java:157)
at org.eclipse.ui.internal.menus.WorkbenchMenuService$5.run(WorkbenchMenuService.java:589)
at org.eclipse.ui.internal.menus.WorkbenchMenuService.processAdditions(WorkbenchMenuService.java:681)
at org.eclipse.ui.internal.menus.WorkbenchMenuService.addContributionsToManager(WorkbenchMenuService.java:769)
at org.eclipse.ui.internal.menus.WorkbenchMenuService.populateContributionManager(WorkbenchMenuService.java:755)
at org.eclipse.ui.internal.menus.SlaveMenuService.populateContributionManager(SlaveMenuService.java:76)
at org.eclipse.ui.internal.WorkbenchWindow.fillActionBars(WorkbenchWindow.java:3543)
at org.eclipse.ui.internal.WorkbenchWindow.<init>(WorkbenchWindow.java:414)
at org.eclipse.ui.internal.tweaklets.Workbench3xImplementation.createWorkbenchWindow(Workbench3xImplementation.java:31)
at org.eclipse.ui.internal.Workbench.newWorkbenchWindow(Workbench.java:1881)
at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:1879)
at org.eclipse.ui.internal.Workbench$21.runWithException(Workbench.java:1199)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4041)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3660)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$31.runWithException(Workbench.java:1567)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2548)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
!ENTRY org.eclipse.ui.workbench 4 2 2013-04-17 15:44:29.147
!STACK 0
!ENTRY org.eclipse.ui 4 0 2013-04-17 15:44:29.673
!MESSAGE Unhandled event loop exception
!STACK 0
at org.eclipse.core.internal.registry.ConfigurationElementHandle.getContributor(ConfigurationElementHandle.java:134)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.getNamespace(ConfigurationElementHandle.java:125)
at org.eclipse.ui.internal.registry.ViewDescriptor.getPluginId(ViewDescriptor.java:208)
at org.eclipse.ui.activities.WorkbenchActivityHelper.createUnifiedId(WorkbenchActivityHelper.java:180)
at org.eclipse.ui.activities.WorkbenchActivityHelper.getIdentifier(WorkbenchActivityHelper.java:57)
at org.eclipse.ui.activities.WorkbenchActivityHelper.allowUseOf(WorkbenchActivityHelper.java:104)
at org.eclipse.ui.activities.WorkbenchActivityHelper.restrictUseOf(WorkbenchActivityHelper.java:122)
at org.eclipse.ui.internal.registry.ViewRegistry.find(ViewRegistry.java:261)
at org.eclipse.ui.internal.PageLayout.checkValidPlaceholderId(PageLayout.java:329)
at org.eclipse.ui.internal.FolderLayout.addPlaceholder(FolderLayout.java:51)
at org.eclipse.cdt.internal.ui.CPerspectiveFactory.createInitialLayout(CPerspectiveFactory.java:41)
at org.eclipse.ui.internal.Perspective.loadPredefinedPersp(Perspective.java:816)
at org.eclipse.ui.internal.Perspective.createPresentation(Perspective.java:270)
at org.eclipse.ui.internal.Perspective.<init>(Perspective.java:156)
at org.eclipse.ui.internal.tweaklets.Workbench3xImplementation.createPerspective(Workbench3xImplementation.java:55)
at org.eclipse.ui.internal.WorkbenchPage.createPerspective(WorkbenchPage.java:1672)
at org.eclipse.ui.internal.WorkbenchPage.openPerspectiveExtras(WorkbenchPage.java:2486)
at org.eclipse.ui.internal.WorkbenchPage.init(WorkbenchPage.java:2439)
at org.eclipse.ui.internal.WorkbenchPage.<init>(WorkbenchPage.java:563)
at org.eclipse.ui.internal.tweaklets.Workbench3xImplementation.createWorkbenchPage(Workbench3xImplementation.java:39)
at org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(WorkbenchWindow.java:768)
at org.eclipse.ui.internal.Workbench$23.runWithException(Workbench.java:1221)
I am on windows 7 and running my RCP which is based on Helios
Previous Topic:Overriding key bindings for editing text
Next Topic:Status Line Contributions Displaying in the wrong order
Current Time: Sun Jul 20 17:55:12 EDT 2025
Powered by FUDForum. Page generated in 0.07906 seconds
