Home » Archived » Hudson » Cobertura Plugins does not show yellow ball
Cobertura Plugins does not show yellow ball [message #1041520] Mon, 15 April 2013 03:45 Go to next message
with the new Version 3.0 of Hudson the Cobertura Plugins does not show the yellow ball when a build is unstable.
I'm using the Version 1.6-h-3 of the plugin.
Re: Cobertura Plugins does not show yellow ball [message #1041791 is a reply to message #1041520] Mon, 15 April 2013 11:30 Go to previous messageGo to next message
Ok. May be a ball color test gone awry. I'll take a look.
Re: Cobertura Plugins does not show yellow ball [message #1042465 is a reply to message #1041791] Tue, 16 April 2013 09:19 Go to previous messageGo to next message
with the Version 1.3 of the plugin the yellow ball and the clouds are ok, without any problem.
Re: Cobertura Plugins does not show yellow ball [message #1042477 is a reply to message #1041791] Tue, 16 April 2013 09:35 Go to previous messageGo to next message
Another tipp,
i think it is a problem with the values of the percentages
In the old Version they seem to be integer values
Take a look.
www.bilder-hochladen.net/files/dfpd-20-7cbb.png
In the new Version they look like float values
www.bilder-hochladen.net/files/dfpd-1y-14bf.png
Re: Cobertura Plugins does not show yellow ball [message #1042483 is a reply to message #1042477] Tue, 16 April 2013 09:40 Go to previous messageGo to next message
After 5 Postings i'm able to link the images directly
Values in the Version 1.3
http://www.bilder-hochladen.net/files/dfpd-20-7cbb.png
Values in the new Version 1.6-h-3
http://www.bilder-hochladen.net/files/dfpd-1y-14bf.png
With the "Float" Values the are no clouds or the yellow ball
Re: Cobertura Plugins does not show yellow ball [message #1043389 is a reply to message #1042483] Wed, 17 April 2013 12:37 Go to previous messageGo to next message
I think there were made the problem.
It is at the Jenkins page, but it is the same code
https://github.com/jenkinsci/cobertura-plugin/commit/9f3026f2513d38ee89945e96b66d1e6dbe26ac9c
Re: Cobertura Plugins does not show yellow ball [message #1043933 is a reply to message #1043389] Thu, 18 April 2013 05:34 Go to previous messageGo to next message
I changed all of this float values to int and after this,
the yellow ball and the clouds are displayed correctly.
The hpi file you can find there
http://www.workupload.com/file/GWIhTH8
Re: Cobertura Plugins does not show yellow ball [message #1044273 is a reply to message #1043933] Thu, 18 April 2013 13:48 Go to previous messageGo to next message
Hi Dirk, would you mind putting your changes at https://github.com/hudson3-plugins/cobertura-plugin. If you have Github account, we will give access
Re: Cobertura Plugins does not show yellow ball [message #1044609 is a reply to message #1044273] Fri, 19 April 2013 01:54 Go to previous messageGo to next message
If want, i can do this.
I created an account with the name DirkHa
Re: Cobertura Plugins does not show yellow ball [message #1045183 is a reply to message #1044609] Fri, 19 April 2013 18:32 Go to previous message
Hi Dirk, thanks. I have given you push/pull access to https://github.com/hudson3-plugins/cobertura-plugin
Previous Topic:Redundancy with Hudson
Next Topic:Maven3 build exception
Current Time: Sun Jul 20 18:02:23 EDT 2025
Powered by FUDForum. Page generated in 0.03840 seconds
