Home » Modeling » Papyrus » DurationConstraints and Oberservations do not work in Kepler M6 release
DurationConstraints and Oberservations do not work in Kepler M6 release [message #1041447] Mon, 15 April 2013 01:41 Go to next message
Hi all,
I was not able to establish time/timing-related elements in a sequence
diagram. This, however, worked well back in 0.8.2. (Not sure about the 0.9.x
releases - never used them).
I checked with today's nightly build of Kepler.
Shall I file a bug?
Marc-Florian
Re: DurationConstraints and Oberservations do not work in Kepler M6 release [message #1041515 is a reply to message #1041447] Mon, 15 April 2013 03:37 Go to previous messageGo to next message
Hi Marc-Florian,
The Sequence Diagram was maintained on the 0.9.X branch only, until a few days after M6. It should work properly on the Kepler nightly builds, however.
So, if something doesn't work properly on Kepler Nightly, you can fill a bug
Thank you,
Camille
Re: DurationConstraints and Oberservations do not work in Kepler M6 release [message #1042233 is a reply to message #1041515] Tue, 16 April 2013 02:36 Go to previous message
Hi Camille,
somthing must have changed.
In 0.9.2 creation of these Time-related constraint was straight forward and
stable, in 0.10.0 nightly, it is very inconvient since the little circles
that indicate the MessageOccurrenceSpecification are not aligned with the
visual message end but somewhere above or below. So, it is in general
possible to establish these constraints and if you have found the
corresponding MessageOccurrenceSpecification of Message, the visual
Constraint is aligned correctly. But as I said, it is very inconvient to
look for these MessageOccurrenceSpecification (that should be at the same
location where the Message end/start hits the Lifeline).
I filed a bug (https://bugs.eclipse.org/bugs/show_bug.cgi?id=405762).
Marc-Florian
"Camille Letavernier" wrote in message news:kkganl$id$1@xxxxxxxxe.org...
Hi Marc-Florian,
however.
Thank you,
Camille
Previous Topic:How to read a file from papyrus via EMF?
Next Topic:activity diagram and deployment diagram
Current Time: Sun Jul 20 14:11:16 EDT 2025
Powered by FUDForum. Page generated in 0.03150 seconds
