Home » Eclipse Projects » Eclipse Platform » register IResourceChangeListener
register IResourceChangeListener [message #1039704] Fri, 12 April 2013 09:32 Go to next message
I have a plugin that implements a custom nature and builder. This plugin has to react on resource changes (for resources in projects with this custom nature). So I create a custom IResourceChangeListener that is registered when my plugin is started.
This works fine when projects are created. But if Eclipse is restarted, I can miss change events because the plugin is not loaded (until a build is triggered).
What is the best way to make sure my plugin is loaded when Eclipse has a project with my custom nature? I'd prefer not to force my plugin to always be loaded, only when there is an open project with my nature.
Hendrik.
Re: register IResourceChangeListener [message #1040820 is a reply to message #1039704] Sun, 14 April 2013 02:00 Go to previous messageGo to next message
Hendrik,
Comments below.
Normally builders are sufficient to maintain state without also needing
a special resource change listener. What is it you need to do before a
build is triggered?
> Hendrik.
Re: register IResourceChangeListener [message #1041139 is a reply to message #1040820] Sun, 14 April 2013 13:39 Go to previous messageGo to next message
Hi Ed,
I need to detect that files are added. I thought IResourceChangeListener was the was the best way to handle this.
But maybe I can do this in the builder too.
Thanks for the suggestion,
Hendrik.
Re: register IResourceChangeListener [message #1041537 is a reply to message #1041139] Mon, 15 April 2013 04:19 Go to previous messageGo to next message
Thanks Ed,
an incremental builder is indeed the easier solution.
Re: register IResourceChangeListener [message #1041560 is a reply to message #1041537] Mon, 15 April 2013 04:47 Go to previous message
Hendrik,
Yes that's exactly what I expected. :-)
On 15/04/2013 10:19 AM, Hendrik Eeckhaut wrote:
> Thanks Ed,
Previous Topic:Team project set must include custom project location
Next Topic:Forcing p2 update
Current Time: Sat Jul 19 23:28:37 EDT 2025
Powered by FUDForum. Page generated in 0.23138 seconds
