Home » Archived » Sapphire » DerivedValueService not working
DerivedValueService not working [message #1038318] Wed, 10 April 2013 14:25 Go to next message
I have a model element with two properties: a ListProperty (containing "wrapped" ReferenceValues) and a String ValueProperty. The value of the second property is derived from the content of the first (it simply concatenates the IDs of all the referenced elements). The properties are as below:
//ListProperty
@Type(base = FusibleRef.class)
@Service(impl=InputIdPossibleValuesService.class)
@Label(full="Inputs", standard="Inputs")
ListProperty PROP_INPUTS = new ListProperty(TYPE, "inputs");
ModelElementList<FusibleRef> getInputs();
//ValueProperty that I want to refresh based on the above ListProperty
@Derived
@DependsOn("inputs")
@Service(impl=FusionFeedDerivedValueService.class)
ValueProperty PROP_FEED = new ValueProperty(TYPE, "Feed");
Value<String> getFeed();
However, my implementation of DerivedValueService is having its compute() method called only once, when the file is opened in the Sapphire editor, and nothing is happening when I make any changes to the "inputs" property. What might I be doing wrong?
Re: DerivedValueService not working [message #1038361 is a reply to message #1038318] Wed, 10 April 2013 15:39 Go to previous messageGo to next message
The issue is with your @DependsOn. As specified, it only catches changes to the list itself (adding an element, removing an element, re-arranging elements). It doesn't catch changes to internal properties of the contained elements. You want something like this instead...
@DependsOn( "Inputs/SomeValueProperty" )
- Konstantin
Re: DerivedValueService not working [message #1038376 is a reply to message #1038361] Wed, 10 April 2013 16:03 Go to previous messageGo to next message
I wondered if something like that were the case, but adding/moving/rearranging elements in the list doesn't trigger the compute() in my DerivedValueService either.
Re: DerivedValueService not working [message #1038387 is a reply to message #1038376] Wed, 10 April 2013 16:23 Go to previous messageGo to next message
Does changing @DependsOn the way I suggested work?
Re: DerivedValueService not working [message #1038393 is a reply to message #1038387] Wed, 10 April 2013 16:31 Go to previous messageGo to next message
Never mind. The @DependsOn annotation causes a property refresh, which will call DerivedValueService.value(), which will not cause the value to be re-computed. The @DependsOn annotation is really a blunt legacy system for wiring up dependencies. The proper way to get DerivedValueService to update is for the service itself to listen on its inputs (override initDerivedValueService() and dispose() to do this). When your listener detects a change, call refresh() method in the service, which will call compute() and broadcast a change if the value changes.
- Konstantin
Re: DerivedValueService not working [message #1038421 is a reply to message #1038393] Wed, 10 April 2013 17:17 Go to previous messageGo to next message
Konstantin-- Thank you. Overriding the other methods did the trick.
This is a related question (and should probably go in another thread), but...if I want to wait on retrieving a referenced element (out of my list property) until the user has had a chance to actually browse for and select one, is there 1) a particular PropertyEvent type to use; 2) an alternative to listening on each individual element in the list?
Re: DerivedValueService not working [message #1038437 is a reply to message #1038421] Wed, 10 April 2013 17:54 Go to previous messageGo to next message
I am not quite sure I understand your question, but I can answer this part:
When you attach a listener, you can use a model path. For instance, using a path like "Inputs/SomeValueProperty" will ensure that you are listening on all current instances of SomeValueProperty as well as all future ones. Sapphire will ensure the listener is propagated to the new elements when list changes.
You will likely want to focus on PropertyContentEvent. See FilteredListener for an easy way to do that. At the very least, you will want to ignore PropertyInitializationEvent.
- Konstantin
Re: DerivedValueService not working [message #1038440 is a reply to message #1038437] Wed, 10 April 2013 17:56 Go to previous message
That is exactly what I was looking for (and you alluded to it above when you suggested changing the path passed to @DependsOn). Learning something new everyday, mostly thanks to you!
Previous Topic:Adding listener to a ListSelectionService from outside Sapphire?
Next Topic:Horizontal layout with fixed width
Current Time: Sat Jul 19 19:00:32 EDT 2025
Powered by FUDForum. Page generated in 0.05996 seconds
