Home » Eclipse Projects » WindowBuilder » Window Builder Design View Problem with SWT(Internal error when opening design view for SWT GUI)
Window Builder Design View Problem with SWT [message #1033752] Thu, 04 April 2013 11:47 Go to next message
I have the latest version of Window Builder Pro installed on my Eclipse 4.2 Juno. When I create a new SWT Application Window, I cannot open the Design view. The code can still be compiled and run, but as soon as I try to open the Design tab a progress bar appears, stops responding after 4-5 seconds, 6-7 seconds after it displays the following error:
Internal Error
WindowBuilder encountered unexpected internal error.
This could be caused by a WindowBuilder bug or by a misconfiguration issue, conflict, partial update, etc.
java.lang.ClassCastException: org.eclipse.swt.widgets.Shell cannot be cast to org.eclipse.swt.widgets.Control
Stack trace:
at org.eclipse.wb.os.OSSupport.endShot(OSSupport.java:142)
at org.eclipse.wb.internal.rcp.support.ToolkitSupportImpl.endShot(ToolkitSupportImpl.java:115)
at org.eclipse.wb.internal.swt.support.ToolkitSupport.endShot(ToolkitSupport.java:92)
at org.eclipse.wb.internal.swt.model.widgets.ControlInfo.refresh_fetch(ControlInfo.java:233)
at org.eclipse.wb.internal.swt.model.widgets.ControlInfo.refresh_fetch(ControlInfo.java:157)
at org.eclipse.wb.internal.swt.model.widgets.ControlInfo.refresh_fetch(ControlInfo.java:124)
at org.eclipse.wb.internal.swt.model.widgets.ScrollableInfo.refresh_fetch(ScrollableInfo.java:49)
at org.eclipse.wb.internal.swt.model.widgets.CompositeInfo.refresh_fetch(CompositeInfo.java:301)
at org.eclipse.wb.core.model.ObjectInfo$6$1.run(ObjectInfo.java:496)
at org.eclipse.wb.internal.core.utils.execution.ExecutionUtils.runDesignTime(ExecutionUtils.java:145)
at org.eclipse.wb.core.model.ObjectInfo$6.run(ObjectInfo.java:494)
at org.eclipse.wb.core.model.ObjectInfo.execRefreshOperation(ObjectInfo.java:514)
at org.eclipse.wb.core.model.ObjectInfo.refresh(ObjectInfo.java:492)
at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF(DesignPage.java:580)
at org.eclipse.wb.internal.core.editor.DesignPage.access$9(DesignPage.java:522)
at org.eclipse.wb.internal.core.editor.DesignPage$8$1.run(DesignPage.java:449)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4687)
at org.eclipse.wb.internal.core.editor.DesignPage$8.run(DesignPage.java:446)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF_withProgress(DesignPage.java:465)
at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF(DesignPage.java:415)
at org.eclipse.wb.internal.core.editor.UndoManager.refreshDesignerEditor(UndoManager.java:381)
at org.eclipse.wb.internal.core.editor.UndoManager.activate(UndoManager.java:90)
at org.eclipse.wb.internal.core.editor.DesignPage.handleActiveState_True(DesignPage.java:263)
at org.eclipse.wb.internal.core.editor.DesignPage.handleActiveState(DesignPage.java:241)
at org.eclipse.wb.internal.core.editor.multi.DefaultMultiMode.showPage(DefaultMultiMode.java:125)
at org.eclipse.wb.internal.core.editor.multi.DefaultMultiMode$1.widgetSelected(DefaultMultiMode.java:63)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:774)
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.java:3028)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:1749)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.java:278)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
The Design tab works fine with Swing GUI.
I have attached the report produced by Eclipse.
Thank you.
Re: Window Builder Design View Problem with SWT [message #1036449 is a reply to message #1033752] Mon, 08 April 2013 08:00 Go to previous messageGo to next message
how does this Shell come there?
Shell e podklas na Control.
Re: Window Builder Design View Problem with SWT [message #1036455 is a reply to message #1033752] Mon, 08 April 2013 08:07 Go to previous messageGo to next message
Vij tova
https://bugs.eclipse.org/bugs/show_bug.cgi?id=387074
Re: Window Builder Design View Problem with SWT [message #1036604 is a reply to message #1036455] Mon, 08 April 2013 11:50 Go to previous messageGo to next message
Hi Binko
I understand that a subclass cannot be cast to its superclass. What I wanted to know is why Window Builder was trying to do that.
Thank you for the link from which it looks like I need to reinstall JRE.
I na bulgarski, blagodarya.
Re: Window Builder Design View Problem with SWT [message #1036616 is a reply to message #1036604] Mon, 08 April 2013 12:02 Go to previous messageGo to next message
A subclass can be cast to its superclass. it doesn't work the other way.
You can cast a Shell to a Control but not a Control to a Shell.
It also depends how the variable is initiated at first place.
But your problem seems to be with the JRE.
The cast should work.
Re: Window Builder Design View Problem with SWT [message #1036620 is a reply to message #1036604] Mon, 08 April 2013 12:05 Go to previous messageGo to next message
The problem may be that your classes are not correctly loaded so that Control is not correctly loaded as superclass of Shell, so that Shell cannot be cast to it.
Re: Window Builder Design View Problem with SWT [message #1036652 is a reply to message #1036620] Mon, 08 April 2013 12:59 Go to previous messageGo to next message
Yes you are right, I got them the other way round for some reason. It turns out I didn't know everything about casting. Smile
I will reinstall JRE and fingers crossed.....
Re: Window Builder Design View Problem with SWT [message #1040127 is a reply to message #1036652] Sat, 13 April 2013 00:10 Go to previous message
I fixed the problem by updating my JDK.
The one I had was JDK SE7 update 13, which I updated to JDK SE7 update 17.
Previous Topic:Data Binding Tab
Next Topic:Issue with Tabbed Pane
Current Time: Sat Jul 19 20:48:04 EDT 2025
Powered by FUDForum. Page generated in 0.03535 seconds
