Home » Archived » Hudson » syntax error near unexpected token....
syntax error near unexpected token.... [message #1023929] Mon, 25 March 2013 09:33 Go to next message
Hi, I've problem with hudson installation.
I've an AWS INSTANCE withs SMALL configuration and Amazon Linux AMI 2012.09.1
I've installed HUDSON with this command:
sudo wget -O /etc/yum.repos.d/hudson.repo http:// hudson-ci.org/redhat/hudson.repo
sudo yum check-update
sudo yum install hudson
After this command, I lunched
service hudson
and it give me this error:
/etc/init.d/hudson: line 120: syntax error near unexpected token `('
/etc/init.d/hudson: line 120: `		echo "${attn} Use try-restart ${done}(LSB)${attn} rather than condrestart ${warn}(RH)${norm}"'
Obviously HUDSON not run....
What's my error?
[Updated on: Tue, 26 March 2013 10:31] by Moderator
Re: syntax error near unexpected token.... [message #1024218 is a reply to message #1023929] Mon, 25 March 2013 21:24 Go to previous messageGo to next message
Hi Allesandro, in your posting the command you used to install is not pasted correctly. Please paste it correctly, so that I can use it reproduce it on my side.
Re: syntax error near unexpected token.... [message #1024239 is a reply to message #1023929] Mon, 25 March 2013 22:09 Go to previous messageGo to next message
What was that command again? It looks like: s
Re: syntax error near unexpected token.... [message #1027084 is a reply to message #1024239] Tue, 26 March 2013 10:31 Go to previous messageGo to next message
I've modify the correct code that I used to install hudson...thanks Wink
Re: syntax error near unexpected token.... [message #1031931 is a reply to message #1027084] Tue, 02 April 2013 07:35 Go to previous messageGo to next message
Hello, got the same issue
* CentOS release 5.9
$> rpm -ivh hudson-3.0.1-1.1.noarch.rpm
$>service hudson status
the issue is probably in line 90
instead of
daemon  --user "$HUDSON_USER" --pidfile "$HUDSON_PID_FILE" "$JAVA_CMD $PARAMS &> /var/tmp/hudson.log &
set it to
daemon  --user "$HUDSON_USER" --pidfile "$HUDSON_PID_FILE" "$JAVA_CMD" "$PARAMS" &> /var/tmp/hudson.log &
then it works fine!
Re: syntax error near unexpected token.... [message #1032199 is a reply to message #1031931] Tue, 02 April 2013 13:43 Go to previous messageGo to next message
Yannis. Thanks. I'll fix this and replace it in the repository
Re: syntax error near unexpected token.... [message #1033657 is a reply to message #1031931] Thu, 04 April 2013 09:38 Go to previous messageGo to next message
Thanks a lot "yannis despotopoulos"....i've solved with your topic Smile
Re: syntax error near unexpected token.... [message #1033823 is a reply to message #1033657] Thu, 04 April 2013 13:27 Go to previous message
Fixed and pushed the new RPM to the repository and verified it on Fedora-17. Thanks again to Yannis for looking in to this. Happy to see community members helping.
Previous Topic:Deleting Hudson Workspace causes this error before build
Next Topic:Failing the Hudson build in case of Java errors
Current Time: Sun Jul 20 03:48:10 EDT 2025
Powered by FUDForum. Page generated in 0.14377 seconds
