Home » Archived » Visual Editor (VE) » Another code generation for SWT/JFACE
Another code generation for SWT/JFACE [message #102733] Thu, 18 August 2005 05:53 Go to next message
Originally posted by: cocktail.cs.tu-berlin.de
I'm rather new to eclipse, VE ... and read several papers about eclipse
plugin development and - of course - also the tutorial to extend the ve -
thats quite a lot of new stuff.
Well - my goal is to get the VE to generate code based on SWT/JFace for a
special extension of Java which of course looks a little bit different to
standard java.
Can anybody give me one (or more) hints where or how to start such a
project? I'm not interested in extending the palette - i want to modify
nearly all of the generated code.
thanks in advance,
Karsten
Re: Another code generation for SWT/JFACE [message #102760 is a reply to message #102733] Thu, 18 August 2005 08:32 Go to previous messageGo to next message
Karsten Meier wrote:
> standard java.
> thanks in advance,
> Karsten
It will be easier for you to start with a simple "Hello World" kind of modification, so that you can
get some hands on familiarity with the how/where things are.
Re: Another code generation for SWT/JFACE [message #102835 is a reply to message #102760] Thu, 18 August 2005 17:27 Go to previous messageGo to next message
Originally posted by: remus.gmx.org
>> Hi,
>> standard java.
>> thanks in advance,
>> Karsten
> modification, so that you can get some hands on familiarity with the
eh - perhaps the explanation was not clear enough. I think i'm above the
"Hello World" level. With the help of several papers I wrote some small
plugins for eclipse and extended the swing palette (the tutorial to do this
was quite helpful).
But nowhere i found any hint in how to extend/modify the way VE, or better
the swt-extension, generates code. Of course browsing the whole VE Code
would explain something but a small hint of one of you experts would help a
lot.
ciao,
Karsten
Re: Another code generation for SWT/JFACE [message #102929 is a reply to message #102835] Fri, 19 August 2005 19:25 Go to previous messageGo to next message
Hi Karsten,
I think what Gili was referring to was something like the "Custom code
generation for the text property" section in the paper for extending the
Visual Editor
( http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /org.eclipse.ve.examples/org.eclipse.ve.example.customwidget /WebContent/index.html),
not 'Hello World' SWT apps.
Sri.
>>>Hi,
>>>standard java.
>>>thanks in advance,
>>>Karsten
> was quite helpful).
> lot.
> ciao,
> Karsten
Re: Another code generation for SWT/JFACE [message #103335 is a reply to message #102929] Wed, 24 August 2005 10:09 Go to previous messageGo to next message
> Hi Karsten,
> Visual Editor
ok - thanks. I misunderstood gili.
Well I know this document and it is quite helpful to extend ve with new
widgets. Of course I will need this part also. But my first problem is to
modify the way the visual class will be generated.
To understand the way (...).ve.swt does this i also studied the code there.
But what i found was not very helpful:
SWT (and swing and ...) all use the "newStyleExtension" to extend the
slection tree in the "new visual class wizard" - but they all just
reference a special Class in the core plugin.
Look here (example from ve.swt):
<extension point="org.eclipse.ve.java.core.newStyleComponent">
<visualElement
contributor=" org.eclipse.ve.internal.java.codegen.wizards.contributors.Sh ellSourceContributor "
name="%NewStyleComponent.Shell">
</visualElement>
</extension>
The ShellSourceContributer just give a name for a code template, that of
course also resides in that core plugin. What is so astonishing: The
core-Plugin contains classes for other (specialized) extensions - here
SWT-Shell. For Swing it is the same situation.
The Problem now: I want to do exactly what SWT does: give a special template
for the visual class - and i would be very happy.
Is there a way to do this _without_ modifying the ve-core?
Hope someone could help.
Karsten
Re: Another code generation for SWT/JFACE [message #103342 is a reply to message #103335] Wed, 24 August 2005 10:22 Go to previous messageGo to next message
You would use the same extension point, but supply your own contributor.
The contributor replies in the getTemplateLocation() method with the
javajet template which is used to extend the code created by the base
NewClassWizard.
The javajet template has all of the template of code to add.
Now how these javajets all work is different story. :-) I don't know how
that works.
Rich Kulp
Re: Another code generation for SWT/JFACE [message #103353 is a reply to message #103335] Wed, 24 August 2005 10:40 Go to previous messageGo to next message
Oh - i forgot to give the used versions:
eclipse 3.0.2
ve 1.0.2
greetings,
Karsten
On Wed, 24 Aug 2005 16:09:41 +0200, Karsten Meier <remus@gmx.org>
wrote:
>Hi,
>> Hi Karsten,
>> Visual Editor
> <visualElement
> </visualElement>
></extension>
>Thanks,
>Karsten
Re: Another code generation for SWT/JFACE [message #103364 is a reply to message #103342] Wed, 24 August 2005 10:53 Go to previous messageGo to next message
On Wed, 24 Aug 2005 10:22:09 -0400, Rich Kulp
>NewClassWizard.
Well, nice idea - i had the same. This contributor is quite easy and
the jjet doesnt look very complicated (there are enough examples).
But: this contributor is never loaded. Even my whole plugin is not
loaded when the "new visual class wizard" is finished.
There has to be something importent i miss. Because i thought that
something from the "custom widget tutorial" will help my plugin also
contains nearly all of the things described there. Everything worked -
except this starting point.
Thanks so far,
Karsten
Re: Another code generation for SWT/JFACE [message #103389 is a reply to message #103364] Wed, 24 August 2005 14:11 Go to previous messageGo to next message
You need to select the style in the style tree before your contributor
will get loaded. For example, if you never select Swing->Frame, then the
Swing frame contributor will not get loaded.
Rich Kulp
Re: Another code generation for SWT/JFACE [message #103484 is a reply to message #103389] Thu, 25 August 2005 01:29 Go to previous messageGo to next message
On Wed, 24 Aug 2005 14:11:20 -0400, Rich Kulp
You are joking, right?
Of course i selected my style - how else should i know that the wizard
is _not_ generating what i want.
Btw: in this case an empty java class is generated.
greetings,
Karsten
Re: Another code generation for SWT/JFACE [message #103599 is a reply to message #103484] Thu, 25 August 2005 07:50 Go to previous message
i tried it all again with a fresh generated plugin and: it works now!
Dont ask me why my first try failed!
Thanks so far,
Karsten
On Thu, 25 Aug 2005 07:29:27 +0200, Karsten Meier <remus@gmx.org>
>greetings,
>Karsten
Re: Another code generation for SWT/JFACE [message #610328 is a reply to message #102733] Thu, 18 August 2005 08:32 Go to previous message
> standard java.
> thanks in advance,
> Karsten
Re: Another code generation for SWT/JFACE [message #610334 is a reply to message #102760] Thu, 18 August 2005 17:27 Go to previous message
>> Hi,
>> standard java.
>> thanks in advance,
>> Karsten
was quite helpful).
lot.
ciao,
Karsten
Re: Another code generation for SWT/JFACE [message #610341 is a reply to message #102835] Fri, 19 August 2005 19:25 Go to previous message
Hi Karsten,
Visual Editor
Sri.
>>>Hi,
>>>standard java.
>>>thanks in advance,
>>>Karsten
> was quite helpful).
> lot.
> ciao,
> Karsten
Re: Another code generation for SWT/JFACE [message #610369 is a reply to message #102929] Wed, 24 August 2005 10:09 Go to previous message
> Hi Karsten,
> Visual Editor
<visualElement
</visualElement>
</extension>
Karsten
Re: Another code generation for SWT/JFACE [message #610370 is a reply to message #103335] Wed, 24 August 2005 10:22 Go to previous message
NewClassWizard.
that works.
Rich Kulp
Re: Another code generation for SWT/JFACE [message #610371 is a reply to message #103335] Wed, 24 August 2005 10:40 Go to previous message
eclipse 3.0.2
ve 1.0.2
greetings,
Karsten
wrote:
>Hi,
>> Hi Karsten,
>> Visual Editor
> <visualElement
> </visualElement>
></extension>
>Thanks,
>Karsten
Re: Another code generation for SWT/JFACE [message #610372 is a reply to message #103342] Wed, 24 August 2005 10:53 Go to previous message
>NewClassWizard.
Thanks so far,
Karsten
Re: Another code generation for SWT/JFACE [message #610374 is a reply to message #103364] Wed, 24 August 2005 14:11 Go to previous message
Rich Kulp
Re: Another code generation for SWT/JFACE [message #610381 is a reply to message #103389] Thu, 25 August 2005 01:29 Go to previous message
greetings,
Karsten
Re: Another code generation for SWT/JFACE [message #610388 is a reply to message #103484] Thu, 25 August 2005 07:50 Go to previous message
Thanks so far,
Karsten
>greetings,
>Karsten
Previous Topic:Editor refreshing
Next Topic:Reviewing / editing VE
Current Time: Sat Jul 19 15:00:39 EDT 2025
Powered by FUDForum. Page generated in 0.08993 seconds
