Home » Eclipse Projects » Rich Client Platform (RCP) » refresh properties view
refresh properties view [message #404503] Thu, 13 January 2005 06:01 Go to next message
I have a RCP app that uses the properties view. The properties that
are shown can be modified within editors. What event should be fired to
let the PropertySheet know that it has to update or do I have to get a
handle to it and do it myself?
Phil
Re: refresh properties view [message #404511 is a reply to message #404503] Thu, 13 January 2005 12:45 Go to previous messageGo to next message
The properties view listens for selection changed events from the
workbench page's selection service, and notifies the current property
page of the change. The default property page updates in response (as
should other implementations).
The view or editor needs to publish its selection provider via
getSite().setSelectionProvider(ISelectionProvider), and issue events to
selection listeners appropriately.
If the view or editor is implemented using a viewer, you can just set
that as the selection provider.
If properties of the selected element are changing without the selection
changing, you may need to issue a fake selection event to get the
properties view to update.
Nick
From within the
> Phil
Re: refresh properties view [message #1033432 is a reply to message #404503] Thu, 04 April 2013 04:13 Go to previous messageGo to next message
Hey everyone,
i know that this thread is about 3 years old, but I have trouble implementing a
"fake selection event" as Nick mentioned:
I have a generated EMF plugin project and created several Sections/Tabs (extended from AbstractPropertySections) for the Properties View. I´m using two different tabs, a "Basic" tab, and an "Advanced" tab.
Now, i want to have a workflow like this: In my custom Editor View (TreeViewer), i want to select an object and edit its Index in the properties view. If the typed value matches a specific Index, the "Advanced" tab should appear immediatly after the "Index-changed" event.
I created an adapter, listening for a index change. It correctly fires every time the index is changed in the properties view. What i wanted to do is to fire the fake selection event so that the classes with implemented IFilter interface run over the currently edited object and create the "Advanced" tab (if the Filter returns true). This works already when selecting an object with mouse/keyboard when a matching index is found.
I want to avoid that the user has to deselect and reselect the object after editing the index in the "Basic" tab, to be able to see the "Advanced" tab.
The following ideas did not resolve my problem:
- Selecting an empty ISelection in TabbedPropertiesSheetPage-Class and reselecting the ISelection of the editor (This causes a loop!)
- Selecting Objects in the Editor TreeViewer (apperently the PropertiesSheetPage is not affected by the changes when firing these events programmatically)
- Selecting the same Selection twice (if-statement in TabbedPropertiesSheetPage with "currentselection.equals(newSelection)" avoids this...
- Refreshing TabbedPropertiesSheetPage (in the spec, it says that only the current Tab is refreshed. Another problem is, that the "Index-changed" event is fired and this results in a loop again)
I also want to avoid overriding TabbePropertiesSheetPage to get arround the if-statement or to affect the currentSelection-object.
Another idea would be to get a valid selection (like the Resource or something) and change it back? I´m really having trouble finding an ISelection or IStructuredSelection element (except the selected object itself) to switch to and back. If you have an idea or other solutions I would be very happy to get some help Smile
[Updated on: Thu, 04 April 2013 08:09] by Moderator
Re: refresh properties view [message #1034294 is a reply to message #1033432] Fri, 05 April 2013 04:58 Go to previous message
I found a solution to my problem. I know it´s dirty, but it works Wink
I used StructuredSelection.EMPTY to get a "valid" selection. Apperently it works just fine when setting the selection to the editor and then setting it to the propertysheetpage. Its also only works when i use the editor-getter in my case. When you have a listener on the property you have to make sure to test / allow the cases: if the object is the same and just the property was changed, or the object is not the same. Otherwise this kind of "refreshing" could trigger the notifier everytime the page refreshes and as you could guess, this results in a loop (if you want to solve this by using an adapter).
//save old selection
ISelection oldSelection = myeditor.getSelection();
//Set the empty selection to the editor
myeditor.setSelection(StructuredSelection.EMPTY);
//set the empty selection to the propertypage the editor contributes to
propertypage.selectionChanged(workbenchpart, editor.getSelection());
//Change back to the old selection to refresh the view
myeditor.setSelection(oldSelection);
I´m still interested in better workarounds if you know any Wink
Joris
[Updated on: Fri, 05 April 2013 05:00] by Moderator
Previous Topic:Empty Selection after opened an editor
Next Topic:load Icons from other Bundle via plugin.xml
Current Time: Sat Jul 19 16:39:06 EDT 2025
Powered by FUDForum. Page generated in 0.15028 seconds
