Home » Modeling » Compare » Diff process on huge file is really long (v2.1.0M6)
Diff process on huge file is really long (v2.1.0M6) [message #1029174] |
Fri, 29 March 2013 04:57  |
I'm currently trying to migrate from 1.2.2 (On which I had made several local hard customizations) to the last version 2.1.0 (M6). But I have really poor performances when comparing a really big file (120Mo, with more than 1 000 000 objects).
It seems that the bottleneck is the diff process which is using a MatchCrossReferencer to check values (most of time, when I pause the threads in debug mode, I see that it is into ComparisonSpec.getInverse(...)). It's taking lot of time for each object in this function, like if the match were redone for each object checked by the diff-engine (what would be strange as the match is already done when making the diff).
I had previously (for version 1.2.2) done a local customization to index in a Map all matched objects by their XMI Id (when there is, which is my case), and it was really improving performances. Did you make the same thing in version 2.1 ? If not, would it resolve the problem, and can I make a clean customization to do so ?
[Updated on: Fri, 29 March 2013 04:58] by Moderator
Re: Diff process on huge file is really long (v2.1.0M6) [message #1032875 is a reply to message #1032592] |
Wed, 03 April 2013 10:54   |
Firstly, thanks for your answer.
About the model, I cannot provide it to you as it is, but it is quite simple:
A container Container has 8 or 9 non-ordered containment references to different type of classes (A, B, C, ...). Each of these classes can also contains 2 or 3 elements (so the sub-structure is really not heavy).
So the model is quite flat. I'll try to share an example...
We strongly encourage users to split their data into several files (Containers can reference other containers), but for our validation, we do the worst case where everything is in one file. I also made a mistake with the size of our big model: it is only about 200 000 objects.
By continuing my investigations about these performances problems, I saw two points:
¤ In DefaultDiffEngine.computeContainmentDifferencesThreeWay(...), we have
Iterables.filter(leftValues, not(containedIn(comparison, lcsOriginLeft))) is used for computing missing elements, and this is iterating, for each object of the resource, over all contained objects (so 200 000 * 200 000 times). This doesn't seems to be efficient as I think that we can already have this non-matched elements list from the previous match process ?
¤ In FeatureFilter.checkForOrderingChanges(...), the order is checked for any containment. I think that this is needed only if we don't have XMIIDs (because in this case references are done thanks to the position of the elements in their container), so it could be interesting to check if XMIIDs are available, in which case only the isOrdered attribute should be taken into account.
Re: Diff process on huge file is really long (v2.1.0M6) [message #1033407 is a reply to message #1032875] |
Thu, 04 April 2013 03:52   |
Guillaume,
I'll use the term "LCS" to talk about the "Longest Common Subsequence" here, you might want to read about it on wikipedia if you wish to understand more on that.
This is why determining differences on very large reference lists is long. The fact that your model is very flat is what makes this process inefficient. Do note that we already reuse the match (and XMIID) information here: "containedIn" will use the comparison to check for matches.
Also, please note that this is not aimed at detected "non-matched" elements. This aims at detecting "objects that are not in the LCS between the two lists": anything that is not part of it is a difference, be it add, delete or move. In other words, we are detecting all differences with these two lines.
We might be able to do a better job here if we "remembered" both the LCS and the rest of the input sequence instead of re-checking afterwards for LCS.contains(). One question though: did you use a profiler to get to these two potential bottlenecks or were you simply "pausing" the process at random?
I do not see why you think having XMIIDs changes anything here. Whether you have IDs or not, your objects might still have moved. And XMIID or not, containment or not, what we call "ordering" is the same: if a reference contains A, B and C on one side, but B and A and C on the other side, then "B" has been moved. We do not check for IDs here.
Laurent Goubet
Obeo
Re: Diff process on huge file is really long (v2.1.0M6) [message #1033497 is a reply to message #1033407] |
Thu, 04 April 2013 05:32   |
Hi Laurent,
I didn't understood that the move change was also including move between two containers (I was only thinking about reordering in the same object containement/reference).
The XMIID thing is that if you don't have ids (XMIID or custom ID), then the references are serialized thanks to the position of the element in its container (something like ../myfolder/fileX.ext#//orders.14), and in this case if an element A is moved into an element B from the 1rst position to the 2nd position, then the references from C to A (for instance) will be broken if the change is not merged. If you have ids, the element A can be moved at any place in the reference (without changing of container and reference) without any impact on object referencing it. In such case, if the containment reference is not ordered, then it's not needed to search for "internal moves".
I think that using the LCS process (and then the containment test with an iteration through the reference content) is something really heavy when the content of the reference is huge, and needed only for the case of reordering in the same reference of the same object. In other cases, checking if there is a match or if the eContainer of the element on both side would be sufficient. I began making tests with such process and it's really, really faster (but I need to improve it and to make more tests to check that I lose nothing).
Also the change you're speaking about ("remembering both the LCS and the rest of the input sequence instead of re-checking afterwards for LCS.contains()") would be better. But in my case, the problem is really this re-iteration to check containment for all elements, even when the reordering (not the move from a container to another) check is not needed.
Last point: yes, I just paused randomly and several times the process... what is not really a good process to find such bottleneck, but I don't know existing good tool for that (I was using TPTP before, but it seems that it has not been updated for Indigo).
Re: Diff process on huge file is really long (v2.1.0M6) [message #1033621 is a reply to message #1029174] |
Thu, 04 April 2013 08:46   |
Here is my improvement for the computeContainmentDifferencesThreeWay method (I'll try to improve also other methods):
protected void computeContainmentDifferencesThreeWay(Match match, EReference reference, boolean checkOrdering) {
final Comparison comparison = match.getComparison();
// We won't use iterables here since we need random access collections
// for fast LCS.
final List<Object> leftValues = getAsList(match.getLeft(), reference);
final List<Object> rightValues = getAsList(match.getRight(), reference);
final List<Object> originValues = getAsList(match.getOrigin(), reference);
// TODO Can we shortcut in any way?
final Iterable<Object> changedLeft;
final Iterable<Object> changedRight;
if (checkOrdering) {
// search common parts
final List<Object> lcsOriginLeft = DiffUtil.longestCommonSubsequence(comparison, originValues, leftValues);
final List<Object> lcsOriginRight = DiffUtil.longestCommonSubsequence(comparison, originValues, rightValues);
// Which values have "changed" in any way?
changedLeft = Iterables.filter(leftValues, not(containedIn(comparison, lcsOriginLeft)));
changedRight = Iterables.filter(rightValues, not(containedIn(comparison, lcsOriginRight)));
} else {
// only search elements moved from a container to another, or added
changedLeft = new ArrayList<Object>();
for (Object obj : leftValues) {
if (obj instanceof EObject) {
Match m = comparison.getMatch((EObject) obj);
if (m != null && m.getOrigin() != null && sameContainment(comparison, m.getOrigin(), (EObject) obj)) {
continue;
((List<Object>) changedLeft).add(obj);
changedRight = new ArrayList<Object>();
for (Object obj : rightValues) {
continue;
((List<Object>) changedRight).add(obj);
// Added or moved in left
for (Object diffCandidate : changedLeft) {
final Match candidateMatch = comparison.getMatch((EObject) diffCandidate);
if (candidateMatch == null || candidateMatch.getOrigin() == null) {
// No matching element here --> It's a ADD
featureChange(match, reference, diffCandidate, DifferenceKind.ADD, DifferenceSource.LEFT);
} else if (!sameContainment(comparison, candidateMatch.getOrigin(), (EObject) diffCandidate)) {
// This is a MOVE (moved from another containment)
featureChange(match, reference, diffCandidate, DifferenceKind.MOVE, DifferenceSource.LEFT);
} else if (checkOrdering) {
* We are dealing with an element which has changed, and we know
* that it's not added nor moved from a containment to another.
* So it can only having been reordered in the same containment
* list:
// Added or moved in right
for (Object diffCandidate : changedRight) {
featureChange(match, reference, diffCandidate, DifferenceKind.ADD, DifferenceSource.RIGHT);
featureChange(match, reference, diffCandidate, DifferenceKind.MOVE, DifferenceSource.RIGHT);
* list:
// deleted from either side
for (Object diffCandidate : originValues) {
* A value that is in the origin but not in the left/right either
* has been deleted or is a moved element which previously was in
* this reference. We'll detect the move on its new reference.
if (candidateMatch == null) {
// out of scope
} else {
if (candidateMatch.getLeft() == null) {
featureChange(match, reference, diffCandidate, DifferenceKind.DELETE, DifferenceSource.LEFT);
if (candidateMatch.getRight() == null) {
featureChange(match, reference, diffCandidate, DifferenceKind.DELETE, DifferenceSource.RIGHT);
* Check if the given two objects are in a container which the same on each
* side, and in the same containment feature.
* @param comparison comparison object
* @param obj1 first object
* @param obj2 second object
* @return true if they are in the same container
protected boolean sameContainment(Comparison comparison, EObject obj1, EObject obj2) {
EObject obj1Cont = obj1.eContainer();
EObject obj2Cont = obj2.eContainer();
Match m1 = comparison.getMatch(obj1Cont);
Match m2 = comparison.getMatch(obj2Cont);
return m1 != null && m2 != null && m1 == m2 && obj1.eContainmentFeature().equals(obj2.eContainmentFeature());
[Updated on: Thu, 04 April 2013 08:47] by Moderator
Re: Diff process on huge file is really long (v2.1.0M6) [message #1033687 is a reply to message #1033497] |
Thu, 04 April 2013 10:19   |
The rationale, was that users often want their models to be "the same" after a merge all... and containment moves, even if unordered, are pretty obvious.
You make a pretty good point though. That will have to be further looked at.
The double-checking you've outlined here (through iterables.filter) is not done to check for move or reordering. It is done to check for both addition and moves.
Though not free, Yourkit does an extremely good job.
I am currently profiling this myself, and you were right on mark. DefaultDiffEngine.contains() is one of two large bottlenecks of the differencing process for such datasets. There are a few possible ways to improve the code without hurting the result (and the performance on more usual datasets).
[Edit: I'll look into the changes you propose here. Please use gerrit to provide us patchs, it is far easier for us to look at. See the wiki.]
[Updated on: Thu, 04 April 2013 10:21] by Moderator
Re: Diff process on huge file is really long (v2.1.0M6) [message #1034490 is a reply to message #1034463] |
Fri, 05 April 2013 09:44   |
Hi Laurent !
Great for this change I hope there will be no problem with such solution.
About using gerrit, I don't use git and cannot access to external git or SVN repositories from my workstation, so I think it's more simple to share the code here (or by mail if you prefer).
And about YourKit, I didn't know it, I think I will have a look at it. Thanks for the advice
One another side, I'm currently working on the computeMultiValuedFeatureDifferencesThreeWay which is also too slow for my bigTestModel, because I have some non-ordered references containing something like 1000 elements. I'm currently working on a solution which does no more use LCS at all, and which does not makes repeated containment checks (I reused a customization I already had done for version 1.2.2)... So it's really faster again, but I have some bugs I want to investigate before sharing the code. The idea is to not search the Longest Common Subsequence, but just to read the two lists simultaneously and to detect on the fly what has been added/removed/moved compared to the reference list (the Origin).
Re: Diff process on huge file is really long (v2.1.0M6) [message #1036469 is a reply to message #1034522] |
Mon, 08 April 2013 08:33   |
Great ! How can I test it ? As I don't have repository access, I can only download released versions...
But I terminated a fix on my side also (with the my custom algorithm).
The idea is the following:
refList : A --> B --> C --> D --> G --> E --> F
newList : A --> G --> C --> D --> G --> E --> F --> B
I read the two lists at same time, but stop advancing on the refList or on the newList when there is a difference. In such case, I continue advancing only on one side until I find the beginning of new matching part. (I join the code in the message)
It is working perfectly fine, but you're right on the point that it is not always giving the best solution (the less changes possible).
For instance, in the example above, it will find
- G added
- C, D , E, F moved
if we invert the lists, it's finding
- G added
- B moved
On another side, by writing this solution, I found another problem in the algorithm you use: it doesn't seems to be working when you have several times the same object in the list (if it not unique). You can try it easily by creating an object with a many Integer attribute (for instance), and comparing 0 --> 1 --> 2 with 0 --> 1 --> 2 --> 0.
Additionnaly, in such case, when looking at differences result, if there is a removal you cannot know which element at which index has been removed. So I think that the algorithm should return changed index (not only changed elements), and it should be stored in the diff.
Re: Diff process on huge file is really long (v2.1.0M6) [message #1036531 is a reply to message #1036471] |
Mon, 08 April 2013 09:57   |
Ok, waiting to test your changes, I remade the algorithm to make it using the LCS system (as it seems to be the best solution). It's now able to compare two lists, by selecting the solution with as less changes as possible, supporting several identical elements, and providing index for each change (even if it's not usefull currently).
The result is provided through 3 lists (added, removed, moved), and so there is no more need for repeated containment checks (as it is done currently to check if the changed value was in the remaining values of the origin list).
Here is the final code using this utility:
Override
protected void computeMultiValuedFeatureDifferencesThreeWay(Match match, EStructuralFeature feature, boolean checkOrdering) {
final List<Object> leftValues = getAsList(match.getLeft(), feature);
final List<Object> rightValues = getAsList(match.getRight(), feature);
final List<Object> originValues = getAsList(match.getOrigin(), feature);
// compute left changes
List<IndexedObject> addedLeft = new ArrayList<IndexedObject>();
List<IndexedObject> removedLeft = new ArrayList<IndexedObject>();
List<IndexedObject> movedLeft = checkOrdering ? new ArrayList<IndexedObject>() : null;
CompareListsUtil.computeListDiff(comparison, originValues, leftValues, addedLeft, removedLeft, movedLeft);
// compute right changes
List<IndexedObject> addedRight = new ArrayList<IndexedObject>();
List<IndexedObject> removedRight = new ArrayList<IndexedObject>();
List<IndexedObject> movedRight = checkOrdering ? new ArrayList<IndexedObject>() : null;
CompareListsUtil.computeListDiff(comparison, originValues, rightValues, addedRight, removedRight, movedRight);
// create final changes left
for (IndexedObject addedLeftObj : addedLeft) {
featureChange(match, feature, addedLeftObj.getObj(), DifferenceKind.ADD, DifferenceSource.LEFT);
for (IndexedObject removedLeftObj : removedLeft) {
featureChange(match, feature, removedLeftObj.getObj(), DifferenceKind.DELETE, DifferenceSource.LEFT);
for (IndexedObject movedLeftObj : movedLeft) {
featureChange(match, feature, movedLeftObj.getObj(), DifferenceKind.MOVE, DifferenceSource.LEFT);
// create final changes right
for (IndexedObject addedRightObj : addedRight) {
featureChange(match, feature, addedRightObj.getObj(), DifferenceKind.ADD, DifferenceSource.RIGHT);
for (IndexedObject removedRightObj : removedRight) {
featureChange(match, feature, removedRightObj.getObj(), DifferenceKind.DELETE, DifferenceSource.RIGHT);
for (IndexedObject movedRightObj : movedRight) {
featureChange(match, feature, movedRightObj.getObj(), DifferenceKind.MOVE, DifferenceSource.RIGHT);
and
final Match candidateMatch = comparison.getMatch((EObject) addedLeftObj.getObj());
if (sameContainment(comparison, candidateMatch.getOrigin(), (EObject) addedLeftObj)) {
featureChange(match, reference, addedLeftObj.getObj(), DifferenceKind.ADD, DifferenceSource.LEFT);
} else {
featureChange(match, reference, addedLeftObj.getObj(), DifferenceKind.MOVE, DifferenceSource.LEFT);
final Match candidateMatch = comparison.getMatch((EObject) removedLeftObj.getObj());
if (candidateMatch != null && candidateMatch.getLeft() == null) {
featureChange(match, reference, removedLeftObj.getObj(), DifferenceKind.DELETE, DifferenceSource.LEFT);
featureChange(match, reference, movedLeftObj.getObj(), DifferenceKind.MOVE, DifferenceSource.LEFT);
final Match candidateMatch = comparison.getMatch((EObject) addedRightObj.getObj());
if (sameContainment(comparison, candidateMatch.getOrigin(), (EObject) addedRightObj)) {
featureChange(match, reference, addedRightObj.getObj(), DifferenceKind.ADD, DifferenceSource.RIGHT);
} else {
featureChange(match, reference, addedRightObj.getObj(), DifferenceKind.MOVE, DifferenceSource.RIGHT);
final Match candidateMatch = comparison.getMatch((EObject) removedRightObj.getObj());
if (candidateMatch != null && candidateMatch.getRight() == null) {
featureChange(match, reference, removedRightObj.getObj(), DifferenceKind.DELETE, DifferenceSource.RIGHT);
featureChange(match, reference, movedRightObj.getObj(), DifferenceKind.MOVE, DifferenceSource.RIGHT);
And I join the new version of the compare utility in a file.
I hope it will be usefull.
About the ordering check for containment, I understand your choice and I still have the possibility to override the FeatureFilter on my side in order to change it. So no problem on this point.
It's great to see how you are attentive to questions on your tool
[EDIT: I also added the code for computeContainmentDifferencesThreeWay()]
[Updated on: Mon, 08 April 2013 10:28] by Moderator
Re: Diff process on huge file is really long (v2.1.0M6) [message #1037132 is a reply to message #1036469] |
Tue, 09 April 2013 03:50   |
Hi Guillaume,
I did not see the message you posted just before my own yesterday, so answers for both:
We should have an integration ready later today, I'll post the link here when it's out of the oven.
There is a lot of documentation on the matter, you could read about the various LCS implementations and the Levenshtein distance if you are interested by the matter.
We chose to use the LCS to solve this as it seemed like the best way, which is why I was a little reluctant on removing it now (I am pretty sure that we would forget about some special cases).
Yes. I saw that too when rewriting the algorithm to remove my stupid filterings. That cas is handled now.
Actually, the LCS elements appear in the same order they do in the actual input lists. As such, we can easily determine the actual index of the changed element if we properly iterate on the LCS "one at a time" instead of pre-filtering as we previously did.
The while loop of computeListDiff really scares me . The exit condition is just too complex to properly read or test.
Furthermore, I believe that there are more comparisons (equal tests) and slightly more iterations in your code than in the change I proposed... I'll run your implementation against our test suite and profile it to check.
Laurent Goubet
Obeo
Re: Diff process on huge file is really long (v2.1.0M6) [message #1037171 is a reply to message #1037132] |
Tue, 09 April 2013 04:40   |
Quote:Actually, the LCS elements appear in the same order they do in the actual input lists. As such, we can easily determine the actual index of the changed element if we properly iterate on the LCS "one at a time" instead of pre-filtering as we previously did.
Hum... The problem I could see is when merging. In this case the index must be re-computed. Are you sure that it's also working when you have several times the same object (is it re-detecting the index of the object at the same index, even if some other changes in the same list on the same object at another index have already been merged ?) ?
I fear that when making such merge it remove/move/add the element at the wrong place if we previoulsy merged a change on an equal object which was also at another place (I don't know if I am really understandable).
Quote:The while loop of computeListDiff really scares me. The exit condition is just too complex to properly read or test.
In computeListDiff, on each step (while iteration) we decide to go to next element for the left and/or the right list, and if we go to next element for both, then we go also for the LCS list. The exit condition is "stop if we will try to get next element on a list where there is no more element".
It's equivalent to:
boolean someEndReached = false;
if (goToNext) {
someEndReached = iterator.hasNext();
if (goToNextRef) {
someEndReached = someEndReached || iteratorRef.hasNext();
if (goToNextRef || goToNext) {
someEndReached = someEndReached || iteratorCommon.hasNext();
\\ and while would be (!someEndReached)
So the maximum complexity is the one for computing LCS + list.size + listRef.size. And the advantage is that with the given result, there is no more need for comparing each leftChange, or rightChange to the originValues with the contains() method (which is really heavy when there is lot of changes, for instance when 4000 elements are added to a list).
I'm sorry if I really insist on such small improvements, but in my case it's really important because the comparison was not taking just 1 hour but really near of one day (or more, I killed the process after that)... and it's an operation which can be done in a normal case, even if we encourage users to have spited models. So any small improvement has really big impacts on performances for such case.
[Updated on: Tue, 09 April 2013 04:50] by Moderator
Re: Diff process on huge file is really long (v2.1.0M6) [message #1037215 is a reply to message #1037171] |
Tue, 09 April 2013 05:50   |
The merge process is not tied to the differencing process. We re-compute the proper insertion index for each merge operation. The user can merge whatever difference first ... so we need to take into account all things that will/won't change when determining the insertion point.
Recomputing the index allows us to be sure that it is good... but it presents its own issues. When merging a single diff, that's fine. However, when "batch" merging differences (using "merge all non conflicting differences" for example), this forces us to re-compute the LCS for every single difference in the list to merge... And that leads to unacceptable performance.
We introduced a batch merging API (IBatchMerger) in order to take this into account... but we do not have an intelligent merger behind that yet. The idea would be to compute the LCS once for a reference where multiple diffs are to be merged, then update it after every merge operation instead of re-computing it from scratch. That's not coded yet though... and not planned for Kepler.
No worries, performance issues as big as the two filters you located are critical enough to fix. However, patches provided through forum are hard to verify and test. As I mentionned, I was looking at yours to run the tests with it and profile its performance.
Your proposed patch provokes 57 test errors (ClassCastException) and 16 failures (we detect more moves with your patch than expected... and some conflicts are not properly detected, but that may be related). Fixing the ClassCast still leaves 27 errors and 27 failures. Performance-wise, your patch performs as well (slightly slower, but that's in the range of experimental errors) as what we have in the pipeline.
Laurent Goubet
Obeo
Current Time: Sun Jul 20 08:42:39 EDT 2025
Powered by FUDForum. Page generated in 0.11354 seconds
