Home » Modeling » GMF (Graphical Modeling Framework) » Multiple label in one node
Multiple label in one node [message #1028128] Wed, 27 March 2013 17:51 Go to next message
Hi !
I would like to know if it's possible to have two label showing two properties on one node.
When i try to do it, the second label is not linked to my node's property, and just show the default value in grey...
Does anyone have an idea about this ?
Thanks a lot !
Valerian
Re: Multiple label in one node [message #1032643 is a reply to message #1028128] Wed, 03 April 2013 04:47 Go to previous messageGo to next message
Hi Valerian,
this should work for any number of attributes/labels.
Check your FeatureLabelMappings, if everything is set ok, especially the featurestoedit and featurestodisplay entries.
Thomas
Re: Multiple label in one node [message #1032658 is a reply to message #1032643] Wed, 03 April 2013 05:06 Go to previous message
Hi Valerian,
you can also use ExpressionLabelMapping in gmfmap. With this you can use OCL to calculate values even from attributes of othe nodes than the one for which the label is displayed.
Ralph
Previous Topic:Highlighting parts of a diagram
Next Topic:Removing all edit policies at once ...
Current Time: Sun Jul 20 06:02:46 EDT 2025
Powered by FUDForum. Page generated in 0.03167 seconds
