Home » Archived » BIRT » Drill Through-Do BIRT API provide any support to Extract Info about child report from Parent report?(I am using Drill Through option in BIRT report design , where master report summarizes the information and sub report provides detailed view. So after uploading a report, I want to get the details of )
Drill Through-Do BIRT API provide any support to Extract Info about child report from Parent report? [message #1031972] Tue, 02 April 2013 08:26 Go to next message
Hello all,
I am using Drill Through option in BIRT report design , where master report summarizes the information and sub report provides detailed view. So after uploading a report, I want to get the details of child report from that report (If it is parent report). Is there any API supprt from BIRT to get that Info or is there any other way to do that ?
Re: Drill Through-Do BIRT API provide any support to Extract Info about child report from Parent rep [message #1032246 is a reply to message #1031972] Tue, 02 April 2013 15:17 Go to previous messageGo to next message
Can you explain what you're trying to do in a little more detail? Thanks.
Re: Drill Through-Do BIRT API provide any support to Extract Info about child report from Parent rep [message #1032701 is a reply to message #1032246] Wed, 03 April 2013 06:15 Go to previous messageGo to next message
I am beginner to BIRT.I Wanted simmilar functionality like getReportName[1] or getDrillThroughReportName[2] provided by ACTION HANDLE class in BIRT.
I should be able to get the target report name from the master report. I unable to find a way to how to use API provided by BIRT, I have only two objects (IReportEngineFactory and IReportRunnable) in my program , using these I am unable to use getActionHandle method which is the only way to instantiate ACtion Handle class object.
If i can get Action handle class then I can use the above mentioned methods to get the Action Handle object. Please help me. Thanks in advance
[1]
http://help.eclipse.org/indigo/index.jsp?topic=/org.eclipse.birt.doc.isv/model/api/org/eclipse/birt/report/model/api/ActionHandle.html
[2]
Re: Drill Through-Do BIRT API provide any support to Extract Info about child report from Parent rep [message #1033336 is a reply to message #1032701] Thu, 04 April 2013 02:07 Go to previous messageGo to next message
Does any one kindly provide solution as soon as possible
Re: Drill Through-Do BIRT API provide any support to Extract Info about child report from Parent rep [message #1033979 is a reply to message #1033336] Thu, 04 April 2013 18:02 Go to previous message
From IReportRunnable you can grab the designHandle. From there, you can access your elements that have drill throughs and get to the action handle. If you had a chart with a drill through on a series, the following would be how you'd get the base url for the drill through:
series.getTriggers().get(1).getAction().getValue().getURLValues().get(0).getBaseUrl();
Previous Topic:Fix color for series in bar chart
Next Topic:Two text field in same line in one cell
Current Time: Sun Jul 20 04:40:50 EDT 2025
Powered by FUDForum. Page generated in 0.05386 seconds
