Home » Language IDEs » C / C++ IDE (CDT) » GDB fails on simple linked list data type
icon9.gif  GDB fails on simple linked list data type [message #1029666] Fri, 29 March 2013 21:17 Go to next message
I am using CDT for FORTRAN development and so far it works absolutely fine. Nevertheless, these days I came across some pretty bad behavior regarding CDT/Phortran and GDB. The following little example code makes GDB crash:
PROGRAM GDB_Fail
    IMPLICIT NONE
    TYPE :: Test_Node
        TYPE(Test_Node), POINTER :: next => null()
        INTEGER data
    END TYPE
    TYPE(Test_Node) :: node_test
    node_test%data = 4 ! Set Breakpoint here ...
END PROGRAM GDB_Fail
Executing the code in debug (-g3 or -g) the debugger stops at the place mentioned in the above code. I have the Variables View opened and want to inspect my linked list. GDB instantly starts bailing out once stopped complaining as such Sad :
Reading symbols from C:\Dev\Eclipse-WS\Fortran\GDB_Fail\Debug\GDB_Fail.exe...done.
.gdbinit: No such file or directory.
[New Thread 1844.0xfd0]
PTR TO -> (        Type test_node
I am using the JUNO SR2 Release for Parallel Development. Besides that I am running on 32bit as well as 64 bit Windows Vista, Windows 7, Windows 8 Systems. For compilation and debugging I am using gfortran(4.7.2) and gdb(7.5) of MinGW.
Does anyone have the same issues? Does anyone know how to get around these problems?
Cheers
Phil
[Updated on: Fri, 29 March 2013 21:20] by Moderator
Re: GDB fails on simple linked list data type [message #1029675 is a reply to message #1029666] Fri, 29 March 2013 21:39 Go to previous messageGo to next message
I just tried it in C. It works fine. So it seems to be up to GDB and Fortran.
#include <stdio.h>
#include <stdlib.h>
int main(void) {
	struct Test_Node {
		struct Test_Node* p_test_node;
		int daten;
	} test_node;
	test_node.daten = 4;
	return EXIT_SUCCESS;
Re: GDB fails on simple linked list data type [message #1032649 is a reply to message #1029666] Wed, 03 April 2013 04:59 Go to previous message
After a bit more investigation, I was able to reproduce the bug not using eclipse.
Inspecting the variable in the derived type holding the null pointer, makes the GDB inspect in an infinite recursive loop.
I have filed it to gdb:
GDB BUG 15326
Confused
Previous Topic:release process
Next Topic:How to get warnings for undeclared functions
Current Time: Sun Jul 20 16:20:27 EDT 2025
Powered by FUDForum. Page generated in 0.06555 seconds
