Home » Archived » BIRT » Modifying a report design with the API
Modifying a report design with the API [message #100807] Tue, 20 December 2005 11:53 Go to next message
Originally posted by: r.tandon.servicepower.com
Anyone got any examples of this working. I'm failing to get this to work but
can't see what I'm doing wrong. Thanks
Re: Modifying a report design with the API [message #101569 is a reply to message #100807] Thu, 22 December 2005 05:08 Go to previous messageGo to next message
Could please you post your code here first?
Cliff Liang
"Rakesh Tandon" <r.tandon@servicepower.com> д
Re: Modifying a report design with the API [message #102045 is a reply to message #101569] Fri, 23 December 2005 07:57 Go to previous messageGo to next message
I would like to configure my datasource at runtime from a set of parameters
I have read in from a configuration file.
I would then need to configure my dataset to use this datasource. Any
examples around this area would be great.
"Cliff Liang" <cliff.liang@benisoft.com> wrote in message
news:dodtve$o49$1@utils.eclipse.org...
> Best regards,
> Cliff Liang
> д
Re: Modifying a report design with the API [message #102894 is a reply to message #102045] Thu, 29 December 2005 02:07 Go to previous message
BIRT model has a lot of test code demostrating how to write code to create
report design, including data source. You can have a look at those samples.
Good luck!
Cliff Liang
Previous Topic:Invalid Javascript expression when using a parameter for a report
Next Topic:TableItemProcessingError ... Java heap space
Current Time: Sun Jul 20 09:51:21 EDT 2025
Powered by FUDForum. Page generated in 0.03626 seconds
