The default value"unbounded" of an attribute [message #1028450] |
Thu, 28 March 2013 05:14  |
I'm modeling a real time operating system (RTOS) using Papyrus and using the Profile in Software Resource Modeling (SRM) of Standard MARTE.
I have an Element Class named "Task", this Class has an attribute "MaxPriority" which its type is an Integer.
I have two requirements:
First, I want to assign the default value "unbounded" for the attribut "MaxPriority" in my Model, , I chose the type Integer but my problem is how to assign "unbounded" which is a String Type to an attribute of type Integer?
Second, I want to know how to get the default value "unbounded" of the attribute "MaxPriority" in java code.
I'd appreciate any help on this.
Thanks in advance
Re: The default value"unbounded" of an attribute [message #1028536 is a reply to message #1028450] |
Thu, 28 March 2013 07:35   |
Hi, Sabrina,
I don't think that "unbounded" is a valid value for an Integer
property. The ' * ' value of the UnlimitedNatural type indicates
"unbounded", but the Integer type has no such value.
Christian
On 2013-03-28 09:14:13 +0000, sabrina ing said:
> type Integer?
> Thanks in advance
FUDForum. Page generated in 0.10776 seconds
