Home » Modeling » Papyrus » The UML metemodel of Papyrus
The UML metemodel of Papyrus [message #1027432] Tue, 26 March 2013 20:44 Go to next message
> In my ATL project ,I need use the model of Papyrus (.uml file),
>but I can't find the UML MeteModel of Papyrus .
>I've spent a long time looking for it ,but did not find it .
>Can you tell me where to find or to download the UML MetaModel of Papyrus
>for my ATL project.
> Thank you very much !
> Look forward to your reply !
Re: The UML metemodel of Papyrus [message #1027643 is a reply to message #1027432] Wed, 27 March 2013 04:10 Go to previous messageGo to next message
Papyrus doesn't provide its own UML Metamodel. Instead, it relies on the standard Eclipse one (from the Eclipse UML2 project).
The URI is: http://www.eclipse.org/uml2/4.0.0/UML, and you can find the Ecore file in the org.eclipse.uml2.uml plug-in
Camille
Re: The UML metemodel of Papyrus [message #1027649 is a reply to message #1027643] Wed, 27 March 2013 04:18 Go to previous messageGo to next message
Thank you for your reply!
I find a URI ,but did not kown that whether these metemodels are UML Metamodels of Papyrus. The URI : http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papyrus/trunk/plugins/uml/org.eclipse.papyrus.uml.standard/model/
Unfortunately, the URL that you give to me ,can not find .
Re: The UML metemodel of Papyrus [message #1027688 is a reply to message #1027649] Wed, 27 March 2013 05:21 Go to previous messageGo to next message
The URI is an EMF URI. Although it starts with http:/, it is not a valid HTTP page. This is just an identifier for the UML Metamodel.
To open the UML.ecore file, you should import the uml plug-in into your workspace (File -> Import -> Plug-ins and Fragments -> choose org.eclipse.uml2.uml), then look into the model/ folder.
Camille
Re: The UML metemodel of Papyrus [message #1027763 is a reply to message #1027688] Wed, 27 March 2013 07:40 Go to previous messageGo to next message
I am sorry that I don't know how to use URI to get the metamodel of UML .Can you give me detailed description of the use of URI to find metamodel of UML ?
Re: The UML metemodel of Papyrus [message #1027796 is a reply to message #1027763] Wed, 27 March 2013 08:25 Go to previous messageGo to next message
The metamodel URI cannot be used to retrieve the metamodel. It is an identifier.
To retrieve the metamodel:
Camille
Re: The UML metemodel of Papyrus [message #1027799 is a reply to message #1027763] Wed, 27 March 2013 08:29 Go to previous messageGo to next message
http://git.eclipse.org/c/emf/org.eclipse.emf.git/tree/plugins/org.eclipse.emf.ecore/model/Ecore.ecore
> metamodel of UML ?
Re: The UML metemodel of Papyrus [message #1027874 is a reply to message #1027796] Wed, 27 March 2013 10:36 Go to previous messageGo to next message
I have found the metamodel of UML by your method .I compare the model file(.uml file) generated by Papyrus with the metamodel ,finding that the generated file is not based on UML metamodel . Can I use UML metamodel as the metamodel of the model file(.uml file) generated by Papyrus ?
Re: The UML metemodel of Papyrus [message #1027880 is a reply to message #1027874] Wed, 27 March 2013 10:42 Go to previous messageGo to next message
What do you mean?
If you are using Papyrus 0.9.X (Juno) or 0.10 (Kepler), then we use this version of the UML Metamodel: http://www.eclipse.org/uml2/4.0.0/UML (Corresponding to UML 2.4.1)
If you are using Papyrus 0.8.X (Indigo), then we use the previous version of the UML Metamodel, i.e.: http://www.eclipse.org/uml2/3.0.0/UML (UML 2.3), which is located in the same plug-in (org.eclipse.uml2.uml/model/UML30.ecore)
Camille
Re: The UML metemodel of Papyrus [message #1028232 is a reply to message #1027880] Wed, 27 March 2013 21:49 Go to previous messageGo to next message
I hava used Papyrus to draw a simple activity diagram .The code of the Activity diagram in .uml file is:
<uml:Model xmi:version="20110701" xmlns:xmi="http://www.omg.org/spec/XMI/20110701" xmlns:uml="http://www.eclipse.org/uml2/4.0.0/UML" xmi:id="_vNMBYJPNEeKDxonErf88qQ" name="model">
  <packagedElement xmi:type="uml:Activity" xmi:id="_vNNPgJPNEeKDxonErf88qQ" name="Activity1" node="_4gWO0JPNEeKDxonErf88qQ _71K1kJPNEeKDxonErf88qQ _-8DuAJPNEeKDxonErf88qQ _LnPAIJPOEeKDxonErf88qQ">
    <edge xmi:type="uml:ControlFlow" xmi:id="_ANKJgJPOEeKDxonErf88qQ" name="ControlFlow1" source="_4gWO0JPNEeKDxonErf88qQ" target="_71K1kJPNEeKDxonErf88qQ">
      <guard xmi:type="uml:LiteralBoolean" xmi:id="_ANLXoJPOEeKDxonErf88qQ" value="true"/>
      <weight xmi:type="uml:LiteralInteger" xmi:id="_ANLXoZPOEeKDxonErf88qQ"/>
    </edge>
    <edge xmi:type="uml:ControlFlow" xmi:id="_BQmjgJPOEeKDxonErf88qQ" name="ControlFlow2" source="_LnPAIJPOEeKDxonErf88qQ" target="_-8DuAJPNEeKDxonErf88qQ">
      <guard xmi:type="uml:LiteralBoolean" xmi:id="_BQnxoJPOEeKDxonErf88qQ" value="true"/>
      <weight xmi:type="uml:LiteralInteger" xmi:id="_BQnxoZPOEeKDxonErf88qQ"/>
    </edge>
    <edge xmi:type="uml:ControlFlow" xmi:id="_PaTpIJPOEeKDxonErf88qQ" name="ControlFlow3" source="_71K1kJPNEeKDxonErf88qQ" target="_LnPAIJPOEeKDxonErf88qQ">
      <guard xmi:type="uml:LiteralBoolean" xmi:id="_PaUQMJPOEeKDxonErf88qQ" value="true"/>
      <weight xmi:type="uml:LiteralInteger" xmi:id="_PaU3QJPOEeKDxonErf88qQ"/>
    </edge>
    <node xmi:type="uml:InitialNode" xmi:id="_4gWO0JPNEeKDxonErf88qQ" name="InitialNode1" outgoing="_ANKJgJPOEeKDxonErf88qQ"/>
    <node xmi:type="uml:OpaqueAction" xmi:id="_71K1kJPNEeKDxonErf88qQ" name="eat" outgoing="_PaTpIJPOEeKDxonErf88qQ" incoming="_ANKJgJPOEeKDxonErf88qQ"/>
    <node xmi:type="uml:ActivityFinalNode" xmi:id="_-8DuAJPNEeKDxonErf88qQ" name="ActivityFinalNode1" incoming="_BQmjgJPOEeKDxonErf88qQ"/>
    <node xmi:type="uml:OpaqueAction" xmi:id="_LnPAIJPOEeKDxonErf88qQ" name="sleep" outgoing="_BQmjgJPOEeKDxonErf88qQ" incoming="_PaTpIJPOEeKDxonErf88qQ"/>
  </packagedElement>
</uml:Model>
I know that node,edge,weight,and guard in the code are references,but I can't find them and their attributes(type ,id ,name ,outgoing and so on)in the metemodel of UML.
I want to use the model file (.uml file )in my ATL project and I also want to use the UML metamodel as the metamodel of the generated model file(.uml file).
I want to know that whether my method can work ?
Look forward to your reply .
Re: The UML metemodel of Papyrus [message #1028434 is a reply to message #1028232] Thu, 28 March 2013 04:46 Go to previous message
Please use new subjects lines for new topics.
Please do not ask the same question on multiple newsgroups.
See reply on ATL newsgroup.
Ed Willink
> value="true"/>
> </edge>
> value="true"/>
> </edge>
> value="true"/>
> </edge>
> </packagedElement>
> </uml:Model>
> file(.uml file).
Previous Topic:How to assign a value for a slot of instance specification
Next Topic:Custom Menu Entry in Create Object of Property
Current Time: Sun Jul 20 02:45:58 EDT 2025
Powered by FUDForum. Page generated in 0.05104 seconds
