Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [CDO] need help with difficult problem
[CDO] need help with difficult problem [message #102518] |
Tue, 13 November 2007 15:07  |
Eike,
Congrats, everything, I mean everything is working well.
However, I have a problem I can't find. I think you have my ecore file
to reference...
When I go to create and add a new ServiceGroup object in one client I
get an error in all other clients that follows.
!ENTRY org.eclipse.ui.workbench 4 2 2007-11-13 12:46:27.381
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 0
java.lang.IllegalStateException: Duplicate version:
NamedEquipmentList@16v1
at
org.eclipse.emf.cdo.internal.protocol.revision.CDORevisionRe solverImpl.addRevision(CDORevisionResolverImpl.java:309)
at
org.eclipse.emf.internal.cdo.protocol.LoadRevisionRequest.co nfirming(LoadRevisionRequest.java:125)
at
org.eclipse.emf.internal.cdo.protocol.LoadRevisionRequest.co nfirming(LoadRevisionRequest.java:1)
at
org.eclipse.net4j.signal.RequestWithConfirmation.execute(Req uestWithConfirmation.java:57)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:130)
at
org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalPr otocol.java:231)
at org.eclipse.net4j.signal.SignalActor.send(SignalActor.java:5 0)
at org.eclipse.net4j.signal.SignalActor.send(SignalActor.java:4 0)
These other clients are refreshing a tree view for the Facility model
object. In the course of calling get modelChildren the following is
called...which seems to cause the error above.
getFacility().getEchostar(). Echostar is the root object which I am
using for some other purpose. If you look at the model Facility contains
NamedEquipmentList.
I don't see anything in my code that looks suspect.
Mark.
Re: [CDO] need help with difficult problem [message #102701 is a reply to message #102687] |
Wed, 14 November 2007 12:08  |
Originally posted by: stepper.sympedia.de
Mark Geib schrieb:
> Eike,
> Is this fix in the new release today.?
Yes, the release notes sometimes take a bit longer to be generated:
http://www.eclipse.org/modeling/emft/news/relnotes.php?proje ct=cdo&version=I200711141128
Eike Stepper
http://wiki.eclipse.org/?title=CDO
http://wiki.eclipse.org/?title=Net4j
> Mark.
> Eike Stepper wrote:
>> Mark,
>> I've described the possible cause and my fix in
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=209773
>> I've also cc'ed Simon because I believe that it relates with the
>> Prefetching feature that he contributed.
>> Regards,
>> Eike Stepper
>> Mark Geib schrieb:
>>> Eike,
>>> file to reference...
>>> I get an error in all other clients that follows.
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> model object. In the course of calling get modelChildren the
>>> following is called...which seems to cause the error above.
>>> contains NamedEquipmentList.
>>> Thanks,
>>> Mark.
Re: [CDO] need help with difficult problem [message #612512 is a reply to message #102518] |
Wed, 14 November 2007 06:09  |
Mark,
Eike Stepper
Mark Geib schrieb:
> Eike,
> to reference...
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> Mark.
Re: [CDO] need help with difficult problem [message #612522 is a reply to message #102615] |
Wed, 14 November 2007 11:47  |
FIXED.
Mark.
Eike Stepper wrote:
> Mark,
> Regards,
> Eike Stepper
> Mark Geib schrieb:
>> Eike,
>> to reference...
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Thanks,
>> Mark.
Re: [CDO] need help with difficult problem [message #612523 is a reply to message #102615] |
Wed, 14 November 2007 11:48  |
Eike,
Mark.
Eike Stepper wrote:
> Mark,
> Regards,
> Eike Stepper
> Mark Geib schrieb:
>> Eike,
>> to reference...
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Thanks,
>> Mark.
Re: [CDO] need help with difficult problem [message #612525 is a reply to message #102687] |
Mark Geib schrieb:
> Eike,
Eike Stepper
> Mark.
> Eike Stepper wrote:
>> Mark,
>> Regards,
>> Eike Stepper
>> Mark Geib schrieb:
>>> Eike,
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Thanks,
>>> Mark.
Current Time: Sat Jul 19 22:47:33 EDT 2025
Powered by FUDForum. Page generated in 0.04443 seconds
