Extend Palette [message #102256] |
Mon, 15 August 2005 15:20  |
I was able to add a custom widget to the Palette following the tutorial. When dropping this custom
widget to a composite, I want to display our custom dialog/wizard instead of the dialog asking for
the Bean Name. Can this be done? What extensions should I use? Thanks.
Re: Extend Palette [message #102686 is a reply to message #102611] |
Wed, 17 August 2005 12:33  |
Gili Mendel wrote:
>> tutorial. When dropping this custom widget to a composite, I want to
>> display our custom dialog/wizard instead of the dialog asking for the
> The naming dialog is opened because of the AnnotationPolicy (put a break
> point in AnnotationPolicy.getDefaultAddAnnotationsCommand()).
> This policy is an editor wide, and is responsible of figuring up what to
> "name" the instance that is being dropped (see
> NameInMemberPropertyDescriptor.getUniqueNamesInComposition() .
> There is no way to override/extend this particular policy. Note that
> this dialog will only come up if the preference is set that way.
> You have the option of creating your own edit part/policies, and
> override the existing ones. You can than add a policy that brings up
> your dialog.
We got it to work. Thanks.
Re: Extend Palette [message #610318 is a reply to message #102256] |
Wed, 17 August 2005 10:20  |
The naming dialog is opened because of the AnnotationPolicy (put a break point in
This policy is an editor wide, and is responsible of figuring up what to "name" the instance that is being dropped (see
There is no way to override/extend this particular policy. Note that this dialog will only come up if the preference is
set that way.
You have the option of creating your own edit part/policies, and override the existing ones. You can than add a policy
that brings up your dialog.
Re: Extend Palette [message #610324 is a reply to message #102611] |
> your dialog.
FUDForum. Page generated in 0.05969 seconds
