Home » Archived » Visual Editor (VE) » Extend Palette
Extend Palette [message #102256] Mon, 15 August 2005 15:20 Go to next message
I was able to add a custom widget to the Palette following the tutorial. When dropping this custom
widget to a composite, I want to display our custom dialog/wizard instead of the dialog asking for
the Bean Name. Can this be done? What extensions should I use? Thanks.
Re: Extend Palette [message #102611 is a reply to message #102256] Wed, 17 August 2005 10:20 Go to previous messageGo to next message
> tutorial. When dropping this custom widget to a composite, I want to
> display our custom dialog/wizard instead of the dialog asking for the
The naming dialog is opened because of the AnnotationPolicy (put a break point in
AnnotationPolicy.getDefaultAddAnnotationsCommand()).
This policy is an editor wide, and is responsible of figuring up what to "name" the instance that is being dropped (see
NameInMemberPropertyDescriptor.getUniqueNamesInComposition() .
There is no way to override/extend this particular policy. Note that this dialog will only come up if the preference is
set that way.
You have the option of creating your own edit part/policies, and override the existing ones. You can than add a policy
that brings up your dialog.
Re: Extend Palette [message #102686 is a reply to message #102611] Wed, 17 August 2005 12:33 Go to previous message
> point in AnnotationPolicy.getDefaultAddAnnotationsCommand()).
> this dialog will only come up if the preference is set that way.
> override the existing ones. You can than add a policy that brings up
> your dialog.
We got it to work. Thanks.
Re: Extend Palette [message #610318 is a reply to message #102256] Wed, 17 August 2005 10:20 Go to previous message
set that way.
Re: Extend Palette [message #610324 is a reply to message #102611] Wed, 17 August 2005 12:33 Go to previous message
> your dialog.
Previous Topic:VE ignores visual class
Next Topic:(newbie) Using VE to create Wizard pages
Current Time: Sat Jul 19 09:36:57 EDT 2025
Powered by FUDForum. Page generated in 0.05200 seconds
