Home » Eclipse Projects » Equinox » Equinox on Websphere and context updates
Equinox on Websphere and context updates [message #102566] Wed, 05 December 2007 18:06 Go to next message
Originally posted by: jacek.pospychala.pl.ibm.com
Dear Equinox,
I've heard from few sources a following concern regarding deploying
Equinox on WebSphere (as well as other app servers).
Equinox works fine there, but when installing additional bundle jars,
app server detects this (new Jar in app area) and reloads whole
application context killing Equinox instance.
Is it a known issue? Does it require any special configuration of
WebSphere, or is it rather misconfiguration of Equinox?
I'm trying to be as precise as I can, but I'm not an expert in app
servers, and it's not me who faced this problem. From my understanding,
Equinox would be fine to install bundles from remote locations, eg. by
issuing "install http://x.y.z/bundle.jar" in console. Then it would
probably make a local copy of that bundle in <configuration> area, which
is hopefully out of WebSphere surveillance. Does it make sense? Or are
there better workarounds?
Thank you for your help,
Jacek
Re: Equinox on Websphere and context updates [message #102580 is a reply to message #102566] Wed, 05 December 2007 21:04 Go to previous messageGo to next message
Originally posted by: zx.us.ibm.com
As far as I know, the latest stable Websphere isn't supporting you
toying with the Equinox instance at all really. I believe WAS will allow
you to deploy OSGi-based applications in a future version.
I could be wrong though.
However, the rumor on the street is that people have used a bundle
within WAS to start another Equinox (via EclipseStarter) and use that
one for all their personal bundles to make sure not to interfere with WAS.
~ Chris
Re: Equinox on Websphere and context updates [message #102652 is a reply to message #102566] Thu, 06 December 2007 08:36 Go to previous messageGo to next message
Jacek,
I am assuming that the equinox deployment mechanism used is the Equinox
Servlet Bridge. If this is the case then there are no issues with adding
new bundles as the the OSGi working area is placed in the
WebApplications temp directory which is not monitored for file changes.
Running the Servlet Bridge in WAS 6.1 is no problem.
BTW turning on/off the monitoring of file changes is something that is
configuration per Application deployment.
Richard
Jacek Pospychala wrote:
> Dear Equinox,
> Jacek
Re: Equinox on Websphere and context updates [message #102743 is a reply to message #102652] Thu, 06 December 2007 16:55 Go to previous message
Thanks Richard,
I like your answer.
Richard Backhouse wrote:
> Jacek,
> Equinox Servlet Bridge. If this is the case then there are no issues
> with adding new bundles as the the OSGi working area is placed in the
> changes. Running the Servlet Bridge in WAS 6.1 is no problem.
> Richard
>> Dear Equinox,
>> understanding, Equinox would be fine to install bundles from remote
>> locations, eg. by issuing "install http://x.y.z/bundle.jar" in
>> console. Then it would probably make a local copy of that bundle in
>> <configuration> area, which is hopefully out of WebSphere
>> surveillance. Does it make sense? Or are there better workarounds?
>> Jacek
Previous Topic:BuddyPolicy Question
Next Topic:Bundle-NativeCode explanation.
Current Time: Sat Jul 19 18:52:36 EDT 2025
Powered by FUDForum. Page generated in 0.65217 seconds
