Home » Archived » Visual Editor (VE) » VE ignores visual class
VE ignores visual class [message #102459] Tue, 16 August 2005 11:45 Go to next message
some days ago I started using subclipse, a plugin for using the subversion
scm with eclipse. Visual Classes are created by using VE. If I check out a
project from subversion (even to the same eclipse installation) VE ignores
the visual classes. As I found in the help system, VE needs only some
hints in the source code to start working. The source code did not change.
Any hints why VE ignores the formerly recognized visual classes?
Michael
Re: VE ignores visual class [message #102471 is a reply to message #102459] Tue, 16 August 2005 12:25 Go to previous messageGo to next message
What do you mean by ignore? Does this mean the regular java editor comes
up, or that the VE comes up with a blank drawing area?
If the regular java editor comes up that means the default editor was
changed for java classes. Just do Open As->Visual Editor to get the
editor back.
If you have blank drawing area then please attach the .log file. There
may be some errors that are preventing it from coming up.
Rich Kulp
Re: VE ignores visual class [message #102498 is a reply to message #102471] Wed, 17 August 2005 03:01 Go to previous messageGo to next message
On Tue, 16 Aug 2005 12:25:43 -0400, Rich Kulp wrote:
Hello Rich,
thanks for your fast answer.
> up, or that the VE comes up with a blank drawing area? If the regular
> java editor comes up that means the default editor was changed for java
> classes. Just do Open As->Visual Editor to get the editor back.
The regular java editor opened. Opening the file the way you described
brought back the visual editor. Maybe it's my fault but somehow I expected
VE to come up by itself again as the @jve tag is still in the file. Now I
found the help section describing how to make VE the default editor.
This is not the case.
Thanks again for your help.
Michael
Re: VE ignores visual class [message #102514 is a reply to message #102498] Wed, 17 August 2005 03:14 Go to previous messageGo to next message
Hello again,
making it the default editor is not so good :) Would be great
if VE came up automatically when the the @jve tag is there.
Michael
Re: VE ignores visual class [message #102636 is a reply to message #102514] Wed, 17 August 2005 10:41 Go to previous messageGo to next message
I don't know how to do that. That requires us parsing every java file
first to determine if the jve tag is there. There is something new
called Content-Type in Eclipse, maybe this can be used, but we don't
know anything about this yet.
michael wrote:
> Hello again,
> Michael
Rich Kulp
Re: VE ignores visual class [message #102674 is a reply to message #102636] Wed, 17 August 2005 10:51 Go to previous message
ok thx for the answer...
Re: VE ignores visual class [message #610308 is a reply to message #102459] Tue, 16 August 2005 12:25 Go to previous message
editor back.
Rich Kulp
Re: VE ignores visual class [message #610310 is a reply to message #102471] Wed, 17 August 2005 03:01 Go to previous message
Hello Rich,
Michael
Re: VE ignores visual class [message #610311 is a reply to message #102498] Wed, 17 August 2005 03:14 Go to previous message
Hello again,
Michael
Re: VE ignores visual class [message #610320 is a reply to message #102514] Wed, 17 August 2005 10:41 Go to previous message
michael wrote:
> Hello again,
> Michael
Rich Kulp
Re: VE ignores visual class [message #610323 is a reply to message #102636] Wed, 17 August 2005 10:51 Go to previous message
Previous Topic:Visualize a custom composite in VE
Next Topic:Extend Palette
Current Time: Sun Jul 20 05:31:05 EDT 2025
Powered by FUDForum. Page generated in 0.11374 seconds
