Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo]Invalid operation: Explicit COMMIT or ROLLBACK is not allowed when in auto-commit mode?
[Teneo]Invalid operation: Explicit COMMIT or ROLLBACK is not allowed when in auto-commit mode? [message #102423] |
Mon, 12 November 2007 10:42  |
Originally posted by: vnikolov.us.ibm.com
Hello Martin,
I'm using Teneo/JPOX with setup datasource/connection pooling on
Websphere Application Server. It is setup by setting
PMFConfiguration.JDO_CONNECTION_FACTORY_NAME_PROPERTY in
JpoxDataStore.setProperties(properties).
When I run my application, on JpoxDataStore.initialize() I get the
following exception:
Exception = com.ibm.db2.jcc.c.SqlException
Source = com.ibm.ws.rsadapter.jdbc.WSJccSQLJConnection.rollback
probeid = 1860
Stack Dump = com.ibm.db2.jcc.c.SqlException:
[ibm][db2][jcc][10114][10307] Invalid operation: Explicit COMMIT or
ROLLBACK is not allowed when in auto-commit mode.
at com.ibm.db2.jcc.c.p.rollback(p.java:752)
at com.ibm.db2.jcc.c.gc.rollback(gc.java:162)
at
com.ibm.ws.rsadapter.jdbc.WSJdbcConnection.rollback(WSJdbcCo nnection.java:2490)
at
org.jpox.store.rdbms.adapter.DB2Adapter.closeConnection(DB2A dapter.java:195)
at org.jpox.store.rdbms.RDBMSManager.closeConnection(RDBMSManag er.java:467)
at
org.jpox.store.rdbms.SchemaAutoStarter.<init>(SchemaAutoStarter.java:139)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at
sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAccessorImpl.java:67)
at
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:5 21)
at org.jpox.util.ClassUtils.newInstance(ClassUtils.java:73)
at org.jpox.store.StoreManager.initialiseAutoStart(StoreManager .java:383)
at
org.jpox.store.rdbms.RDBMSManager.initialiseSchema(RDBMSMana ger.java:735)
at org.jpox.store.rdbms.RDBMSManager.<init>(RDBMSManager.java:268)
at
at
at
org.jpox.store.StoreManagerFactory.getStoreManager(StoreMana gerFactory.java:73)
at
org.jpox.AbstractPersistenceManager.getStoreManager(Abstract PersistenceManager.java:295)
at
org.jpox.AbstractPersistenceManager.<init>(AbstractPersistenceManager.java:217)
at org.jpox.PersistenceManagerImpl.<init>(PersistenceManagerImpl.java:42)
at
org.jpox.PersistenceManagerFactoryImpl.getPersistenceManager (PersistenceManagerFactoryImpl.java:178)
at
org.jpox.PersistenceManagerFactoryImpl.getPersistenceManager (PersistenceManagerFactoryImpl.java:153)
at
org.eclipse.emf.teneo.jpox.JpoxDataStore.createSchema(JpoxDa taStore.java:515)
at
org.eclipse.emf.teneo.jpox.JpoxDataStore.initialize(JpoxData Store.java:213)
I started debbuging the problem and I found out that
connection.autoCommit property is set to true in
org.jpox.store.rdbms.adapter.DatabaseAdapter.getConnection() method.
Here is the code snippet:
if (isolationLevel == Connection.TRANSACTION_NONE) {
conn.setAutoCommit(true);
else {
if (conn.getAutoCommit()) {
conn.setAutoCommit(false);
This only happens with localPmf persistence manager factory from
JpoxDataStore.createSchema() method. At runtime, while using the default
pmf of the JpoxDataStore the autoCommit property is set to false in
Also at runtime(after JpoxDataStore.initialize() is over), I'm
observing a warning messages from time to time. The warning message says:
WLTC0033W: Resource jdbc/myDS rolled back in cleanup of
LocalTransactionContainment.
LocalTranCoor W WLTC0032W: One or more local transaction resources
were rolled back during the cleanup of a LocalTransactionContainment.
Probably the exception and the warning are related, but the exception
is thrown during initialization and the warnings are displayed during
runtime after the initialization is over.
Is there something I'm missing? An option to set or improper
initialization?
Here is my configuration:
- ================ DatabaseAdapter ==================
16:42:17,694 (WebContainer : 0) INFO [JPOX.RDBMS] - Adapter :
16:42:17,694 (WebContainer : 0) INFO [JPOX.RDBMS] - Datastore :
name="DB2/NT" version="SQL09010" (major=9, minor=1, revision=0)
16:42:17,694 (WebContainer : 0) INFO [JPOX.RDBMS] - Driver : name="IBM
DB2 JDBC Universal Driver Architecture" version="3.1.57" (major=3, minor=1)
16:42:17,694 (WebContainer : 0) DEBUG [JPOX.RDBMS] - Identifier Cases :
UPPERCASE "MixedCase-Sensitive"
16:42:17,694 (WebContainer : 0) DEBUG [JPOX.RDBMS] - Identifier Lengths
: Table=128 Column=30 Constraint=18 Index=18 Delimeters="
16:42:17,694 (WebContainer : 0) DEBUG [JPOX.RDBMS] - Identifier Support
in DDL : catalog=false schema=true
16:42:17,694 (WebContainer : 0) DEBUG [JPOX.RDBMS] - Statement Batching
: true
16:42:17,694 (WebContainer : 0) DEBUG [JPOX.RDBMS] - JDBC Types
supported : LONGVARCHAR, BINARY, TIMESTAMP, VARBINARY, TIME,
LONGVARBINARY, BIGINT, DATE, OTHER, CLOB, BLOB, DISTINCT, VARCHAR,
DOUBLE, REAL, SMALLINT, INTEGER, DECIMAL, CHAR
16:41:26,753 (WebContainer : 0) DEBUG [JPOX.JDO] - ================ PMF
Configuration For Schema Creation================
16:41:26,753 (WebContainer : 0) DEBUG [JPOX.JDO] - JDK : 1.5.0 on Windows XP
16:41:26,753 (WebContainer : 0) DEBUG [JPOX.JDO] - JDO Standard Options
: singlethreaded, retainValues, nontransactionalRead
16:41:26,753 (WebContainer : 0) DEBUG [JPOX.JDO] - Persistence Options :
reachability-at-commit deletion-policy=JPOX
16:41:26,753 (WebContainer : 0) DEBUG [JPOX.JDO] - Datastore :
AutoCreate(Tables,Columns,Constraints),
Validate(Tables,Columns,Constraints), CheckTableViewExistence,
foreignKeyCreateMode=AUTO
16:41:26,753 (WebContainer : 0) DEBUG [JPOX.JDO] - Datastore Identifiers
: Factory="jpox"
16:41:26,753 (WebContainer : 0) DEBUG [JPOX.JDO] - MetaData : XML
Validation=true, File Suffixes (JDO = jdo, ORM = orm, JDOQUERY =
jdoquery), ORM Mapping name=(none)
16:41:26,753 (WebContainer : 0) DEBUG [JPOX.JDO] - Datastore Connection
Pooling : None
16:41:26,753 (WebContainer : 0) DEBUG [JPOX.JDO] - Types Control :
stringDefaultLength=255, dateTimezone=UTC
16:41:26,753 (WebContainer : 0) DEBUG [JPOX.JDO] - Initialisation :
mechanism=SchemaTable, mode=Quiet
16:41:26,753 (WebContainer : 0) DEBUG [JPOX.JDO] - Transactions :
type=ResourceLocal, mode=pessimistic, isolation=READ_COMMITTED POID -
isolation=READ_COMMITTED, connection=New
16:41:26,753 (WebContainer : 0) DEBUG [JPOX.JDO] - ClassLoading : jdo
16:41:26,753 (WebContainer : 0) DEBUG [JPOX.JDO] - Cache : Level1
(org.eclipse.emf.teneo.jpox.cache.EMFWeakRefCache), Collections/Maps
16:41:26,753 (WebContainer : 0) DEBUG [JPOX.JDO] - Queries :
fetchSize=0, fetchDirection=forward, resultSetType=forward-only,
resultSetConcurrency=read-only
16:42:16,991 (WebContainer : 0) DEBUG [JPOX.JDO] - ================ PMF
Configuration Runtime ================
16:42:16,991 (WebContainer : 0) DEBUG [JPOX.JDO] - JDK : 1.5.0 on Windows XP
16:42:16,991 (WebContainer : 0) DEBUG [JPOX.JDO] - JDO Standard Options
16:42:16,991 (WebContainer : 0) DEBUG [JPOX.JDO] - Persistence Options :
16:42:16,991 (WebContainer : 0) DEBUG [JPOX.JDO] - Datastore :
AutoCreate(None), Validate(None), CheckTableViewExistence,
16:42:16,991 (WebContainer : 0) DEBUG [JPOX.JDO] - Datastore Identifiers
: Factory="jpox"
16:42:16,991 (WebContainer : 0) DEBUG [JPOX.JDO] - MetaData : XML
16:42:16,991 (WebContainer : 0) DEBUG [JPOX.JDO] - Datastore Connection
Pooling : None
16:42:16,991 (WebContainer : 0) DEBUG [JPOX.JDO] - Types Control :
16:42:16,991 (WebContainer : 0) DEBUG [JPOX.JDO] - Initialisation :
mechanism=Classes, mode=Quiet, classes= .........here are listed a lot
of classes....
16:42:16,991 (WebContainer : 0) DEBUG [JPOX.JDO] - Transactions :
16:42:16,991 (WebContainer : 0) DEBUG [JPOX.JDO] - ClassLoading : jdo
16:42:16,991 (WebContainer : 0) DEBUG [JPOX.JDO] - Cache : Level1
16:42:16,991 (WebContainer : 0) DEBUG [JPOX.JDO] - Queries :
Re: [Teneo]Invalid operation: Explicit COMMIT or ROLLBACK is not allowed when in auto-commit mode? [message #102452 is a reply to message #102423] |
Mon, 12 November 2007 14:42  |
Hi Vladimir,
I think this is more a jpox than a Teneo issue. To me if the connection has autocommit=true then
jpox should not call a rollback. This line SchemaAutoStarter.<init>(SchemaAutoStarter.java:139) is
in a finally block. Does the program get there normally or did an exception occur?
Otherwise I would ask the jpox forum about this.
gr. Martin
Vladimir Nikolov wrote:
> Hello Martin,
> probeid = 1860
> at
> at
> at
> at
> Method)
> at
> at
> at
> at
> Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> else {
> initialization?
> Thanks
> : true
> Windows XP
> : Factory="jpox"
> Pooling : None
> Windows XP
> : Factory="jpox"
> Pooling : None
> of classes....
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo]Invalid operation: Explicit COMMIT or ROLLBACK is not allowed when in auto-commit mode? [message #612482 is a reply to message #102423] |
Hi Vladimir,
gr. Martin
> Hello Martin,
> probeid = 1860
> at
> at
> at
> at
> Method)
> at
> at
> at
> at
> Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> else {
> initialization?
> Thanks
> : true
> Windows XP
> : Factory="jpox"
> Pooling : None
> Windows XP
> : Factory="jpox"
> Pooling : None
> of classes....
The Netherlands
Current Time: Sun Jul 20 07:58:30 EDT 2025
Powered by FUDForum. Page generated in 0.04999 seconds
