Home » Modeling » GMF (Graphical Modeling Framework) » Giving "Generated NOT" in plugin.xml
Giving "Generated NOT" in plugin.xml [message #102236] Thu, 08 February 2007 07:07 Go to next message
Originally posted by: biju_gopinathan.rediffmail.com
Hi friends,
As we give "Generated NOT" in the generated source code, how can we
protect the custom added dependency elements in plugin.xml, from not
being lost in the next diagram code generation.
Thanks in advance Regards biju
Re: Giving "Generated NOT" in plugin.xml [message #102265 is a reply to message #102236] Thu, 08 February 2007 07:30 Go to previous messageGo to next message
Hello biju,
Hope this helps: http://wiki.eclipse.org/index.php/GMF_New_and_Noteworthy#Mer ge_for_plugin.xml
Alex Shatalin
Re: Giving "Generated NOT" in plugin.xml [message #102491 is a reply to message #102265] Fri, 09 February 2007 03:57 Go to previous messageGo to next message
Hello Alex Shatalin ,
Thanks for your reply,
I got the solution for protecting custom added extrensions , that is:
<!-- gmf generator persistent region begin -->
......custom added extrensions.....
<!-- gmf generator persistent region end -->
Like that how can we protect the , custom added dependencies, in the
depandancies tab of plugin.xml
Thanks and Regards biju
Alex Shatalin wrote:
> Hello biju,
> Hope this helps:
> Alex Shatalin
Re: Giving "Generated NOT" in plugin.xml [message #102874 is a reply to message #102491] Mon, 12 February 2007 05:53 Go to previous message
Originally posted by: 5d5.mail.ru
Dependencies are stored in MANIFEST.MF and there is no merging support
for it. The problem is that there is no consensus on which merging
strategy to use.
>> Hello biju,
>> Hope this helps:
>> Alex Shatalin
Previous Topic:GridLayout
Next Topic:Connection for nodes
Current Time: Sun Jul 20 18:28:15 EDT 2025
Powered by FUDForum. Page generated in 0.04364 seconds
