Home » Archived » BIRT » create SQL-Querys dynamically
create SQL-Querys dynamically [message #1022242] Thu, 21 March 2013 10:30
Hi All,
i have to solve a problem in eclipse BIRT with dynamically created querys/datasets.
I'm comming from Oracle Report, and want to use/migrate/redesign my reports.
The problem is, in Oracle-Reports i can use PL/SQL and SQL querys built in Reports.
Example:
  FUNCTION BeforeReport
  RETURN BOOLEAN
  IS
    l_value VARCHAR2(256);
  BEGIN
    SELECT mycol
    INTO l_value
    FROM mytable
    WHERE ....;
    IF(l_value == 'whatever')THEN
      -- TODO
      RETURN TRUE;
    END IF;
    RETURN FALSE;
  EXCEPTION
    WHEN NO_DATA_FOUND THEN
      RETURN FALSE;
  END BeforeReport;
The question is, how can i execute new querys or create NEW DataSets (please without a dummy Dataset and beforeopen event)
consume the resultset and close the cursor etc.
What i found, is the way over a existing Dataset, manipulate textQuery etc.
I want to create a javascript library to put in usefull funtions and procedures.
Example of pseudo code:
  function executeQuery(p_datasource, p_query, p_params)
    // check the paramters
    if(p_datasource == null || p_query == null)
      return null;
    var connection = p_datasource;
    var statement = p_datasource.prepareStatement(p_query);
    statement.setParameter(1, p_params[1]);
    var res = statement.execute_query();
    return res;
somewhere in report
  var resultset = executeQuery("myDataSource", "SELECT mycol FROM mytable WHERE user_id > ?", "5");
  while(resultset.hasnext){
    var myvalue = resultset.next().getValue("mycol");
    // do somewaht
  resultset.close();
PS:
sorry for my bad english.
Any ideas?
Previous Topic:How to check parameters
Next Topic:Table Cell block height
Current Time: Sun Jul 20 03:10:52 EDT 2025
Powered by FUDForum. Page generated in 0.03595 seconds
