Home » Modeling » EMF » [CDO/EMF] Ecore SubPackages & CDOPackage reading
[CDO/EMF] Ecore SubPackages & CDOPackage reading [message #1021715] Wed, 20 March 2013 11:04 Go to next message
Hi everyone.
I have an Ecore model with root & subpackage as :
xxx.yyy.model
xxx.yyy.model.subpackage
When CDO server starts, it reads PackageUnits from database doing :
SELECT unit, uri, parent FROM cdo_package_infos
It seems that my both packages (root & sub) have the same unit : xxx.yyy.model.
The problem is that read packages are put in a HashMap, so I obtains only one entry for both packages.
So it causes a NPE in MetaDataManager.loadPackageUnit() when trying to resolve package with id="xxx.yyy.model".
If I go down in stack strace in CDOPackageRegistryImpl(EPackageRegistryImpl).getEPackage(String), I obtain this for parameter nsURI="xxx.yyy.model"
ePackageDescriptor (CDOPackageInfoImpl) :
CDOPackageInfo[packageURI=xxx.yyy.model, parentURI=null]
CDOPackageUnit[id=xxx.yyy.model.subpackage, state=PROXY, ...]
Does CDO support ECore subpackages ??
[Updated on: Wed, 20 March 2013 11:05] by Moderator
Re: [CDO/EMF] Ecore SubPackages & CDOPackage reading [message #1021719 is a reply to message #1021715] Wed, 20 March 2013 11:12 Go to previous messageGo to next message
Found this :
Changed mapping of CDOPackageUnit to prevent multiple records for the same CDOPackageUnit
On this page :
http://permalink.gmane.org/gmane.comp.ide.eclipse.cdo.scm/380
Will CDO 4.1 fix my problem ???
Re: [CDO/EMF] Ecore SubPackages & CDOPackage reading [message #1021801 is a reply to message #1021719] Wed, 20 March 2013 13:55 Go to previous messageGo to next message
Am 20.03.2013 16:12, schrieb ben ben:
> Found this :
> On this page :
I really hope so, but you should definitely try it. I'm not aware of current problems with subpackages.
Please note that 4.0 is out of maintenance and 4.2 is very near ;-)
Cheers
/Eike
http://www.esc-net.de
Re: [CDO/EMF] Ecore SubPackages & CDOPackage reading [message #1022054 is a reply to message #1021801] Thu, 21 March 2013 03:55 Go to previous message
Thanks for your reply Eike.
I tried 4.1-SR2, I can't definitely be sure it fixes my bug cause my previous database (HSQLDB) is aleady corrupted, but I've seen in debug that each PackageUnit is now associated with several PackageInfos containing all subpackages.
Wait and see if my database doesn't become corrupted anymore but all this stuff seems to be good Wink
[Updated on: Thu, 21 March 2013 03:56] by Moderator
Previous Topic:CDO export/import of data
Next Topic:Databinding with resource as root
Current Time: Sun Jul 20 18:26:07 EDT 2025
Powered by FUDForum. Page generated in 0.06041 seconds
