Home » Modeling » EMF » Standalone vs editor model compatibility
Standalone vs editor model compatibility [message #1021538] Wed, 20 March 2013 05:38 Go to next message
Hi everyone !
I'm trying tu build a standalone application, just a few swing form to edit my model.
I was able to make my app be able to read my .schema file with this code :
String path=f.getCanonicalPath();
ResourceSet resourceSet = new ResourceSetImpl();
        			resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put(Resource.Factory.Registry.DEFAULT_EXTENSION, new XMIResourceFactoryImpl());
resourceSet.getPackageRegistry().put(SchemaPackage.eNS_URI,  schemapack);
resource = resourceSet.getResource(URI.createFileURI(path), true);
EList<EObject> list = resource.getContents();
Everythings used to work fine (i mean i was able to work on the sime file with both my standalone app and the generated editor).
But i made a little change (deleted à EReference from the model), regenerated the code (model, edit and editor) and now, my standalone app can't load my file anymore.
Caused by: org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'consignementReport' is not found or is abstract. (file:/D:/Mes%20documents/Test/workspace/sim-sgr/My.schema, 2, 58)
My Ecore say that the root EClass is DocumentRoot, which contains some ConsignementReportModel, and the containment reference is called consignementReport
And my problematic .schema file start with
<schema:consignementReport xmlns:schema="urn:sia-schema">
I guess the problem is here, my standalone app need the class name, and if i change it to ConsignementReportModel it's ok for the app, but not for the editor anymore..
So I would like to know how i can make them work together again and what is wrong in my code.
Valerian
Re: Standalone vs editor model compatibility [message #1021566 is a reply to message #1021538] Wed, 20 March 2013 06:16 Go to previous messageGo to next message
Valerian,
Comments below.
On 20/03/2013 10:38 AM, Valerian Merkling wrote:
> Hi everyone !
> edit my model.
> code :
> consignementReport
> And my problematic .schema file start with <schema:consignementReport
If your model is XML Schema based, you should use the generated resource
factory everywhere, including in your stand alone application. Try
invoking Generate Test Code... and have a look at the registrations in
the generated XyzExample.java; that's what you should use for stand
alone (and what should be registered in the plugin.xml and used when
running in Eclipse).
> Regards,
> Valerian
Re: Standalone vs editor model compatibility [message #1021647 is a reply to message #1021566] Wed, 20 March 2013 09:06 Go to previous message
Perfect, it works, thanks a lot !
Previous Topic:Referenced objects not loaded
Next Topic:[CDO/EMF] latest stable integration build, code compatibility
Current Time: Sun Jul 20 16:44:56 EDT 2025
Powered by FUDForum. Page generated in 0.04071 seconds
