Home » Modeling » Papyrus » Rename Controlled Model File Error(Rename Controlled Model File Error)
Rename Controlled Model File Error [message #1021509] Wed, 20 March 2013 04:50 Go to next message
I used Papyrus Nightly Build, N201303200043 (2013/03/20)
The error occurs when
- I controlled a package named Package11.
index.php/fa/13938/0/
- I rename the contolled model Package11 to Package111.
index.php/fa/13939/0/
- Rename is successfully done.
index.php/fa/13940/0/
- I close the 'model' which has the controlled package and reopen the 'model' then the error occurs.
index.php/fa/13941/0/
I found where the problem came from.
But I don't know how to fix it.
The problem is that 'org.eclipse.papyrus.infra.ui.resources.refactoring.ModelParticipantHelpers.getResourceToFix(IFile)' returns only .uml files(model.uml and Package11.uml) even though the model.di file should be returned and modified together.
Please help me up fixing this problem.
Re: Rename Controlled Model File Error [message #1021526 is a reply to message #1021509] Wed, 20 March 2013 05:18 Go to previous messageGo to next message
just a quick guess : when you rename a project, there is a dialog (Select Rename Options) which offers an option to analyze the impact of the renaming at Project (default value) or Workspace level.
Did you make sure that the entire Workspace is analyzed ?
index.php/fa/13942/0/
HTH.
Re: Rename Controlled Model File Error [message #1021965 is a reply to message #1021526] Wed, 20 March 2013 22:11 Go to previous messageGo to next message
Yes, the error still occurs even when I selected 'Workspace', and I think that is natural because both 'model.di' and 'Package11.di' are under the same Project.
I found further information.
The inner class 'ScopeChooserVisitor' of org.eclipse.papyrus.infra.ui.resources.refactoring.ui.ScopeChooser needs to be modified to fix this error.
index.php/fa/13956/0/
The 'isXMI(IFile)' returns false on the '.notation' file and '.di' file,
because 'contentType' of line 81 is null on those file types.
I try to fix it if possible. Cool
Re: Rename Controlled Model File Error [message #1021989 is a reply to message #1021965] Wed, 20 March 2013 23:51 Go to previous message
I solved this problem. Laughing
Just contributing contentType for '.di' and '.notation' to the Papyrus using 'org.eclipse.core.contenttype.contentTypes' extension point fixes this error.
Here goes a snippet for the contentType contributions.
<extension point="org.eclipse.core.contenttype.contentTypes">
  <content-type
    base-type="org.eclipse.uml2.uml"
    default-charset="UTF-8"
    file-extensions="di"
    id="my.resource.di_0_9_2"
    name="%_UI_DI_0_9_2_content_type"
    priority="normal">
    <describer
      class="org.eclipse.emf.ecore.xmi.impl.RootXMLContentHandlerImpl$Describer">
      <parameter
        name="namespace"
        value="http://www.eclipse.org/papyrus/0.7.0/sashdi">
      </parameter>
      <parameter
        name="kind"
        value="xmi">
      </parameter>
    </describer>
  </content-type>
  <content-type
    file-extensions="notation"
    id="my.resource.notation_0_9_2"
    name="%_UI_NOTATION_0_9_2_content_type"
    priority="normal">
    <describer
      <parameter
        name="namespace"
        value="http://www.eclipse.org/gmf/runtime/1.0.2/notation">
      </parameter>
      <parameter
        name="kind"
        value="xmi">
      </parameter>
    </describer>
  </content-type>
</extension>
Previous Topic:Displaying a long constraint in a combined fragment
Next Topic:Can I use 'self' in sequence diagram?
Current Time: Sun Jul 20 18:52:22 EDT 2025
Powered by FUDForum. Page generated in 0.24562 seconds
