Home » Modeling » QVT-OML » Tansformation with Multiple source models - Single output model(Is it possible to define a transformation with multiple source models and a single output model?)
Tansformation with Multiple source models - Single output model [message #1020534] Mon, 18 March 2013 07:59 Go to next message
I am fairly new to model driven development question and I would really appreciate some help.
Is there a way to have multiple source models (conforming to the same metamodel) as input?
I tried the following but I get error: "Type of transformation parameter should be model type" so I guess a sequence of ASTs is not a valid input parameter.
modeltype AST uses 'AST uri';
modeltype senslmetamodel uses 'DSL uri';
transformation AST2PIM(in selnsAST:Sequence(AST), out PIM:senslmetamodel);
P.S. The same applies to output model. I thought of a workaround: parse all the XMIs into one big XMI and transform it but I think it is not a clean solution.
Re: Tansformation with Multiple source models - Single output model [message #1020689 is a reply to message #1020534] Mon, 18 March 2013 14:21 Go to previous messageGo to next message
HI
You have defined an input model that is a Sequence.
If you want multiople input models spercify multiple inputs models and
use the @ to navigate around them
Alternatively rather than define a meg-XMI, define a contents meta-model
that represents your 'Sequence;' and then transform from the contents model.
Ed Willink
On 18/03/2013 18:12, Paul Rontidis wrote:
> Hello,
Re: Tansformation with Multiple source models - Single output model [message #1020695 is a reply to message #1020689] Mon, 18 March 2013 14:38 Go to previous messageGo to next message
Thank you for replying.
Ed Willink wrote on Mon, 18 March 2013 14:21
HI
Excuse me if I am wrong, do you mean that I should specify something like "(in senslAST1, in senslAST2, ...)?
If this is the case, it is not adequate because I have an arbitrary numbers of input models, not know beforehand.
[Updated on: Mon, 18 March 2013 16:39] by Moderator
Re: Tansformation with Multiple source models - Single output model [message #1020707 is a reply to message #1020695] Mon, 18 March 2013 15:19 Go to previous messageGo to next message
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
<body text="#000000" bgcolor="#FFFFFF">
<div class="moz-cite-prefix">Hi<br>
<br>
Which is why the second part of my response suggested a contents
meta-model.<br>
<br>
<i>Alternatively rather than define a meg-XMI, define a contents
meta-model that represents your 'Sequence;' and then transform
</i><br>
<br>
Please read.<br>
<br>
    Regards<br>
<br>
        Ed Willink<br>
<br>
On 18/03/2013 18:38, Paul Rontidis wrote:<br>
</div>
<blockquote cite="mid:ki7muk$boj$1@xxxxxxxxe.org" type="cite">Thank
you for replying.
<br>
<br>
<br>
<blockquote type="cite">HI
<br>
models and use the @ to navigate around them
<br>
</blockquote>
<br>
something like "(in senslAST1, in senslAST2, ...)? If this is the
case, itis not adequate in my case because I have an arbitrary
<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
Re: Tansformation with Multiple source models - Single output model [message #1020719 is a reply to message #1020534] Mon, 18 March 2013 15:57 Go to previous messageGo to next message
Hi Paul,
QVTo doesn't provide support for an arbitrary number of model
parameters. They need to be know as well as their model types (i.e
metamodels).
As Ed suggested in a different reply, try to create a Metamodel
decorator with just one class (MyASTGroup) and a multi-valued
containment reference whose type is AST.
modeltype MyASTGroup uses 'MyASTGroupAST uri';
transformation AST2PIM(in selnsAST:MyASTGroup, out PIM:senslmetamodel);
Then your input parameter is just one MyASGroup but it may contain as
many ASTs as you want.
Adolfo.
> Hello,
> parameter.
> clean solution.
Re: Tansformation with Multiple source models - Single output model [message #1021191 is a reply to message #1020534] Tue, 19 March 2013 12:26 Go to previous messageGo to next message
Thank you for proposing this solution, I created the aggregation ecore and wrote the simple transformation.
For my task to be completed I guess I need to write a simple Java program that creates the ASTGroup instance.
Re: Tansformation with Multiple source models - Single output model [message #1021202 is a reply to message #1021191] Tue, 19 March 2013 12:40 Go to previous message
If it's a true *.ecore you can use an auto-generated Ecore editor to
give you a Tree Editor for your aggregator.
If you're really over-enthusiastic you can use Xtext to create a
mini-DSL and text editor.
Ed Willink
> and wrote the simple transformation. For my task to be completed I
> instance.
Previous Topic:Memory Leak
Next Topic:[Announce] Eclipse QVT Operational 3.3.0 (Kepler) M6 is now available
Current Time: Sat Jul 19 06:50:33 EDT 2025
Powered by FUDForum. Page generated in 0.24695 seconds
