createResource() returns null, what am I missing? [message #1020238] |
Sun, 17 March 2013 13:19  |
I'm trying to use EMF in a servlet so I'm having to create a lot of the
default environment by hand. To start up my model I'm trying to do the
following:
FlowchartPackage flowchartPackage = FlowchartPackage.eINSTANCE;
FlowchartFactory flowchartFactory = FlowchartFactory.eINSTANCE;
// Create a resource set and register the package and resource factory
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getPackageRegistry().put(flowchartPackage.getNsURI(),
flowchartPackage);
resourceSet.getResourceFactoryRegistry().getContentTypeToFactoryMap().put(fileExtension,
new XMIResourceFactoryImpl());
// Generate the root object
FlowDiagram flowDiagram = flowchartFactory.createFlowDiagram();
EcoreUtil.setID(flowDiagram, EcoreUtil.generateUUID());
// Create the file uri & resource to save
File file = new File("test." + fileExtension);
URI fileURI = URI.createURI(file.getAbsolutePath());
/////// This returns null?
Resource resource = resourceSet.createResource(fileURI);
/////// This causes a null pointer exception as a result
resource.getContents().add(flowDiagram);
I thought that adding the package and the XMI resource factory by hand
was all I required to create resouces but I must be missing something.
Any suggestions on what I need to do?
Thanks for any help, Nigel.
Re: createResource() returns null, what am I missing? [message #1020275 is a reply to message #1020243] |
Sun, 17 March 2013 15:52   |
Hi Ed,
thanks for that, it's now working. I appreciate the help.
Nigel
On 17/03/2013 17:30, Ed Willink wrote:
> Hi
> You may get on better using the extension factory map for extensions.
> Regards
> Ed Willink
> On 17/03/2013 17:19, Nigel Daniels wrote:
>> Hi,
>> the default environment by hand. To start up my model I'm trying to do
>> the following:
>> flowchartPackage);
Re: createResource() returns null, what am I missing? [message #1020281 is a reply to message #1020243] |
Sun, 17 March 2013 16:15  |
Hi Ed,
Nigel
> Hi
> Regards
> Ed Willink
>> Hi,
>> the following:
>> flowchartPackage);
FUDForum. Page generated in 0.04750 seconds
