Home » Modeling » EMF » [CDO] Start own bundle in CDO Server
[CDO] Start own bundle in CDO Server [message #946554] |
Tue, 16 October 2012 05:36  |
I have a CDO server where I would like to add my own bundle. The bundle contains (CDO) code that reacts to a model change and does an operation (writes a file)).
It turns out to be really hard to start the "new" bundle together with the CDO server because:
- Either it will not start at all...
- Or it will start BEFORE CDO, which is not working since the bundle needs to create a CDO Session.
How can I do this properly?
Is there an CDO related osgi service or something that my bundle can depend on to make it start after the CDO server?
///Anders
Re: [CDO] Start own bundle in CDO Server [message #947618 is a reply to message #947606] |
Wed, 17 October 2012 04:43   |
Am 17.10.2012 10:29, schrieb Anders Jönsson:
>> You may want to implement and contribute an org.eclipse.emf.cdo.spi.server.IAppExtension
> Yes, it works perfect. Thanks a lot!
Excellent ;-)
> I use CDO client code in IAppExtension.start() to connect to the (same) server via tcp,
Why not via JVM transport? That would be faster.
> start a session, open a view and listen to the model. Is this the preferred way to interact with the model
Yes.
> or is there a more direct way to, for instance, open a view using CDO server code?
You can open a ServerCDOView with these methods:
org.eclipse.emf.cdo.server.CDOServerUtil.openView(ISession, CDOBranchPoint, boolean, CDORevisionProvider)
org.eclipse.emf.cdo.server.CDOServerUtil.openView(ISession, CDOBranchPoint, boolean)
org.eclipse.emf.cdo.server.CDOServerUtil.openView(IView, boolean)
org.eclipse.emf.cdo.server.CDOServerUtil.openView(CommitContext, boolean)
But they have very limited capabilities, no write access, no invalidations. Just what's needed to traverse a state of
the model graph in terms of EObjects.
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Start own bundle in CDO Server [message #1021194 is a reply to message #1021193] |
Tue, 19 March 2013 12:28   |
On 19-03-13 17:27, Christophe Bouhier wrote:
> On 19-03-13 16:03, Anders Jönsson wrote:
>> Hi, thanks for suggestions!
BTW, I really recommend to checkout the cdo test plugin, it has tons of
examples.
>> But, when i put my thingy in place of the "...DO YOUR THINGY HERE"
>> thingy I still get an exception:
>> org.eclipse.net4j.util.lifecycle.LifecycleException: Could not activate
>> TCPClientConnector[127.0.0.1:2,036]
> Is your code capable to open a TCPClientConnector without the Extension
> mechanism that I described earlier?
>> The "thingy" here beeing that I am trying to create a CDOSession to the
>> server using tcp (apparently I should use "jvm transport" instead but I
>> haven't gotten around to that yet).
> ah, that's a different issue.
> here is a snippet.
> final IManagedContainer container = IPluginContainer.INSTANCE;
> acceptor = JVMUtil.getAcceptor(container, "default");
> connector = JVMUtil.getConnector(container, "default");
> // Create configuration
> final CDONet4jSessionConfiguration sessionConfiguration =
> CDONet4jUtil
> .createNet4jSessionConfiguration();
> sessionConfiguration.setConnector(connector);
> sessionConfiguration.setRepositoryName(REPO_NAME);
>> And the output below still happens after that (at least it is PRINTED to
>> the log after the stack trace):
>> [INFO] Net4j extension starting
>> !ENTRY org.eclipse.emf.cdo.server.net4j 1 0 2013-03-19 15:30:43.627
>> !MESSAGE Net4j extension starting
>> [INFO] Net4j extension started
>> !ENTRY org.eclipse.emf.cdo.server.net4j 1 0 2013-03-19 15:30:43.641
>> !MESSAGE Net4j extension started
>> [INFO] CDO server started
>> !ENTRY org.eclipse.emf.cdo.server 1 0 2013-03-19 15:30:43.642
>> !MESSAGE CDO server started
>> Also; Eike, can you give me a little more hint about what "the
>> configured acceptor" is.
>> ///Anders
Re: [CDO] Start own bundle in CDO Server [message #1021219 is a reply to message #1021126] |
Tue, 19 March 2013 13:16   |
Hej Anders,
I meant that if you rely on a TCP connection to the repository you should not listen for repository activation but for
the TCP acceptor activation, in Christophe's words:
public Object process(IManagedContainer container, String productGroup,
String factoryType, String description, Object element) {
if (element instanceof ITCPAcceptor) {
final ITCPAcceptor acceptor = (ITCPAcceptor) element;
acceptor.addListener(new LifecycleEventAdapter() {
public void notifyLifecycleEvent(ILifecycleEvent event) {
if (event.getKind() == Kind.ACTIVATED) {
return element;
The acceptor is always started after the repository, i.e. in the Net4j extension.
Does that help?
Cheers
/Eike
Am 19.03.2013 16:03, schrieb Anders Jönsson:
> But, when i put my thingy in place of the "...DO YOUR THINGY HERE" thingy I still get an exception:
> org.eclipse.net4j.util.lifecycle.LifecycleException: Could not activate TCPClientConnector[127.0.0.1:2,036]
> The "thingy" here beeing that I am trying to create a CDOSession to the server using tcp (apparently I should use "jvm
> transport" instead but I haven't gotten around to that yet).
> And the output below still happens after that (at least it is PRINTED to the log after the stack trace):
> Also; Eike, can you give me a little more hint about what "the configured acceptor" is.
> ///Anders
Current Time: Sun Jul 20 13:08:48 EDT 2025
Powered by FUDForum. Page generated in 0.04772 seconds
