Home » Modeling » OCL » asOrderedSet() flattening too much?
| asOrderedSet() flattening too much? [message #1018337] |
Wed, 13 March 2013 12:26  |
I have the following method [*] in a completeOCL document
context Container
def : crossProduct(toAppend : OrderedSet(Integer), currentSet : OrderedSet(OrderedSet(Integer))) : OrderedSet(OrderedSet(Integer)) =
toAppend->iterate( c : Integer; paths : OrderedSet(OrderedSet(Integer)) = currentSet |
let origSet : OrderedSet(OrderedSet(Integer)) = currentSet in (paths->collect( s : OrderedSet(Integer) | s->append(c) ))->asOrderedSet()->union(origSet)->asOrderedSet()
However, the parser yields an error on the union operation
Unresolved Operation 'OrderedSet(Integer)::union(OrderedSet(OrderedSet(Integer)))'
So it looks like the (first) asOrderedSet() operation is flattening the Sequence(OrderedSet(Integer) (ie. the result of the collect() operation) into an OrderedSet(Integer), instead of "just removing" the duplicate elements and returning an OrderedSet(OrderedSet(Integer)).
Is this a bug, or is something wrong with my expression anyway?
TIA
Klaas
[*] Its goal is to create "crossProducts", ie.
crossProduct( {5, 6} , { {1, 2} {3, 4} }) should return { {1 , 2, 5}, {3, 4, 5}, {1, 2, 6}, {3, 4, 6} }.
Also as a side note: in reality, the operation is not meant to be executed on Integers (ie. I don't have the risk of duplicates)
| Re: asOrderedSet() flattening too much? [message #1019004 is a reply to message #1018337] |
Thu, 14 March 2013 17:58   |
In my development workspace, I get a strange dangling reference message
on the "s", but when I hover over the -> of paths->collect I can see the
specialization
IteratorExp *OrderedSet(OrderedSet(Integer))::collect(s :
OrderedSet(Integer) | OrderedSet(Integer)) : Sequence(Integer)*
which is correct. collect was specified in the early days of OCL when
there were no nested collections; it flattens. You need collectNested.
Ed Willink
On 13/03/2013 16:26, Klaas Gadeyne wrote:
> context Container
> OrderedSet(OrderedSet(Integer)) = currentSet | let origSet :
> TIA
> Klaas
Current Time: Sun Nov 02 11:04:38 EST 2025
Powered by FUDForum. Page generated in 0.49610 seconds
