Home » Archived » BIRT » PDFRender - OutputStream not closed ?
PDFRender - OutputStream not closed ? [message #1018881] Thu, 14 March 2013 12:03 Go to next message
In an Eclipse RCP application, I have a report which is generated by default in HTML and displayed in the standard Web viewer. After that, the user can choose to export the report in PDF, XLS, etc.
To do this, the HTML rendering is separated in two tasks : a Run task and a Render task. Like this, the Run task generate a rptDocument file which can be reused for the different exports.
My problem occures with the PDF export. In fact, one time in three, the PDF file is well created but it's still locked by the JVM, thus I can't open or delete the file. If I close my application, the lock is released and I can correctly open or delete the pdf file.
Is it a Bug or do I forget to close something correctly ?
Here is the code of my export :
  // Open the rptDocument
  reportDocument = getReportEngine().openReportDocument(rptDocumentPath);
  // Create the render task, configured for the wanted export format
  IRenderTask renderTask = getReportEngine().createRenderTask(reportDocument);
  IRenderOption options = new RenderOption();
  options.setOutputFormat("pdf");
  options.setOutputFileName("myfile.pdf");
  renderTask.setRenderOption(options);
  try {
    // Launch the render task and close it
    renderTask.render();
    renderTask.close();
    // Close the rptDocument
    reportDocument.close();
    // Finally, open the target file with the right application
    Program.launch(exportFileName);
  } catch (final EngineException e) {
    Syso ....
Re: PDFRender - OutputStream not closed ? [message #1018888 is a reply to message #1018881] Thu, 14 March 2013 12:14 Go to previous messageGo to next message
Can you try:
options.setOption(IRenderOption.CLOSE_OUTPUTSTREAM_ON_EXIT, true);
Re: PDFRender - OutputStream not closed ? [message #1020462 is a reply to message #1018888] Mon, 18 March 2013 04:32 Go to previous messageGo to next message
I tried to add this option in my render task but I still have the problem...
Re: PDFRender - OutputStream not closed ? [message #1021165 is a reply to message #1020462] Tue, 19 March 2013 11:40 Go to previous messageGo to next message
What version of BIRT are you using? I just tried this with 3.7.2 in a sample RCP app I have and I created the pdf in a local folder like c:/test/mypdf.pdf. It worked fine. I ran the code then was able to delete the file with no issue.
Re: PDFRender - OutputStream not closed ? [message #1021581 is a reply to message #1021165] Wed, 20 March 2013 06:49 Go to previous messageGo to next message
Yes, I use BIRT 3.7.2.
The fact is it was correctly working with a RunAndRender task, but now that we have distinct Run and Render tasks, the problem occured...
Re: PDFRender - OutputStream not closed ? [message #1022385 is a reply to message #1021581] Thu, 21 March 2013 15:23 Go to previous messageGo to next message
Jonathan,
I tried it with 3.7.2 using similar code to yours (separate run and render tasks). Are you storing the pdf on the local filesystem or in the workspace. I would like to recreate the issue.
Re: PDFRender - OutputStream not closed ? [message #1027813 is a reply to message #1022385] Wed, 27 March 2013 08:48 Go to previous messageGo to next message
Sorry for the delay,
In fact I store the pdf file outside the workspace, but the rptDocument is stored under a folder temp created in the workspace, under my project root.
Re: PDFRender - OutputStream not closed ? [message #1029753 is a reply to message #1027813] Sat, 30 March 2013 00:47 Go to previous message
I did a similar thing. I created a output directory under my project root named output and when I generated the rptdocument I wrote it to this directory:
task.run("output/resample/pdf.rptdocument");
I then read it like:
IReportDocument doc= engine.openReportDocument("output/resample/pdf.rptdocument");
Later I did a doc.close();
Previous Topic:Graph contains 4 marker lines, some not needed
Next Topic:How to set the zoom value when rendering in pdf?
Current Time: Sun Jul 20 09:04:58 EDT 2025
Powered by FUDForum. Page generated in 0.05219 seconds
