Home » Modeling » QVT-OML » Memory Leak
Memory Leak [message #1018282] Wed, 13 March 2013 10:57 Go to next message
Hi all.
I have task to expand the existing qvto script. Volume of data to be processed is large but not critical. The resulting file in my estimatino will not exceed 30Mb.
And everything was fine, but the script is terminated using all the memory (I allocated 1024m win32). I use profiler and
Somehow number of EValueImpl objects increased
below the results of my profiling
my.jetscreenshot.com/demo/20130313-zbi1-257kb
my.jetscreenshot.com/demo/20130313-06fj-175kb
Re: Memory Leak [message #1018316 is a reply to message #1018282] Wed, 13 March 2013 11:51 Go to previous messageGo to next message
Without a way to reproduce the problem, it's not trivial to diagnose.
From your screenshot it looks like some leaking around the traces
management. I've raised[1] a vague descriptive bugzilla[1] in the same
way vague/lack of test cases/reproducible example.
Adolfo.
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=403219
Re: Memory Leak [message #1018329 is a reply to message #1018282] Wed, 13 March 2013 12:07 Go to previous messageGo to next message
What existing qvto script?
What is the basis for your 30MB estimation?
With models, there is usually very little point looking at thousands of
small objects, much better to look at the relatively small number of
Resource/ResourceSet.
What do the priofile results mean...
You need to do a lot more work yourself before we can look at anything.
Ed Willink
> Hi all.
Re: Memory Leak [message #1018816 is a reply to message #1018329] Thu, 14 March 2013 10:23 Go to previous messageGo to next message
I have found piece of code with the problem:
mapping uml::Property::recursiveProcedure(
		inout parentNode : mdmi::Bag,
		in parentContainerClass : uml::Class,
		in someData: Dict(String, Integer),
		in someData1: someType1,
		in someDataN: someTypeN) {
	if (some_conditions) then{ // so recursion is not infinite!!!
			bag := generateBag(self, parentContainerClass);
			self.type.oclAsType(uml::Class).ownedAttribute->
                          select(attr| (attr.lower >= 0 or attr.name = "templateId"))->map
				recursiveProcedure( bag,
                                self.type.oclAsType(uml::Class),
				someData1,
				someData2,
		                someDataN);
	}  endif;
It uses recursion to tree traversal UML model. The tree is quite deep (20) and wide.
I think that when we exit the recursive function, memory does not free.
I did some experiments:
1) Changed the number of passed someData arguments. As expected the more arguments the faster memory is lost
2) Use inout instead of in (I hoped we pass reference and do not create a copy of object) did not help
3) Tried to clear object(ofcourse obj := null doesn't work becouse it is input argument) since I've been experimenting with a type Dict
someData->clear();
someData1->clear();
someDataN->clear();
memory leak was much slower. but still on.
So what can I do for fix it?
I really do not want to refuse recursion, because the existing script is really big and I will rewrite it too long.
Re: Memory Leak [message #1018868 is a reply to message #1018816] Thu, 14 March 2013 11:36 Go to previous message
Hi Yaroslav,
Suggestions:
1. If you doesn't need any mapping extension mechanism and any
traceability, I suggest you using a "helper" operation rather than a
"mapping" operation, because the former doesn't deal with traces.
2. Go on the discussion in the open bugzilla [1]. It would be great if
you provide some test cases in which we may reproduce the problem.
3. If something works for you, I'd recommend sharing the solution with
the community ;) (We haven't received any feedback from the suggestion
we did in your other question ;) )
Adolfo.
On 14/03/2013 14:23, yaroslav Molodkov wrote:
> ... in someDataN: someTypeN) {
> recursiveProcedure( bag, self.type.oclAsType(uml::Class),
> someData1,
> someData2,
> someDataN);
> } endif;
> (20) and wide.
> someData->clear();
> someData1->clear();
> someDataN->clear();
> So what can I do for fix it? I really do not want to refuse recursion,
Previous Topic:Using blackbox in a qvt transformation called by java
Next Topic:Tansformation with Multiple source models - Single output model
Current Time: Sun Jul 20 05:59:19 EDT 2025
Powered by FUDForum. Page generated in 0.04274 seconds
