Home » Eclipse Projects » Eclipse 4 » Reload application model at runtime(Is it possible?)
Reload application model at runtime [message #1018324] Wed, 13 March 2013 12:01 Go to next message
I wrote my own IModelResourceHandler implementation to load the application.e4xmi from a database at startup. But, is there a possibility to replace the application model at runtime?
I tried the following code, but it leads to a NullPointerException:
IPresentationEngine engine = ..
IModelResourceHandler handler = ..
Resource resource = handler.loadMostRecentModel();
MApplication reloadedApp = (MApplication) resource.getContents().get(0);
engine.run(reloadedApp, context);
Is there a better way to do this or is it generally impossible?
Best regards
Matthias
Re: Reload application model at runtime [message #1018332 is a reply to message #1018324] Wed, 13 March 2013 12:14 Go to previous messageGo to next message
it would definately help to see the NPE. I'm not sure but I don't see
you setting the IEclipseContext for the MApplication-Element!
I think the correct approach would be anyways to create a new instance
of E4Workbench and tear down the old one. The problem I see is that if
you tear down the first E4Workbench the Equinox-Application exit, so you
probably need to write your own E4Application.
Might I ask why you are not simply restarting the whole application?
Tom
Am 13.03.13 17:05, schrieb Matthias Renz:
> Best regards
> Matthias
Re: Reload application model at runtime [message #1018340 is a reply to message #1018332] Wed, 13 March 2013 12:30 Go to previous messageGo to next message
Thank you very much, Thomas!
I forgot to set the IEclipseContext to the new application object.
Now, the thing is that a new shell is being opened. I think I must close the old window referencing the old application model.
I have no Idea, how to dispose the old model and close its window.
IPersistanceEngine.removeGui() has no effect.
How can I do that?
[Updated on: Thu, 14 March 2013 03:16] by Moderator
Re: Reload application model at runtime [message #1083131 is a reply to message #1018340] Fri, 09 August 2013 10:12 Go to previous message
I have the same problem here!
Did you get it working? Can you direct me to a solution?
Sandro
Previous Topic:Open perspective
Next Topic:DI in activator with Compatibility layer
Current Time: Sun Jul 20 14:13:51 EDT 2025
Powered by FUDForum. Page generated in 0.03852 seconds
