Home » Eclipse Projects » Eclipse 4 » Problems with contributing a perspective via fragment
Problems with contributing a perspective via fragment [message #1018241] |
Wed, 13 March 2013 09:22  |
I try to add a new perspective from an other bundle via the fragment.e4xmi.
My application bundle was build with the "Eclipse E4 Application
Project" wizard.
There I only delete the existing perspective from the perspective stack.
As long as I start the whole app with the -clearPersistedState option,
it looks and works fine.
Because I also do persist some preferences I now try to start my app
without these option, I've got the following stacktrace:
What am I doing wrong?
Greetings
Heiko
Stacktrace:
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2013-03-13 13:38:03.937
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.e4.ui.workbench.swt".
!STACK 0
at
org.eclipse.e4.ui.model.internal.ModelUtils.getContainingContext(ModelUtils.java:181)
at
org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.getContainingContext(ModelServiceImpl.java:280)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.getContext(PartRenderingEngine.java:674)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:727)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:702)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:696)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:681)
at
org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
at
org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:98)
at
org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:645)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:731)
at
at
at
at
org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:59)
at
org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:644)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:641)
at
at
at
at
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:987)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
at
org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at
org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:150)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
!ENTRY org.eclipse.e4.ui.workbench 4 0 2013-03-13 13:38:03.952
!MESSAGE Exception occurred while rendering:
org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveImpl@1cf7aa0
(elementId: de.icc.perspective.twitter, tags: [], contributorURI:
platform:/plugin/de.icc.twitter.ui) (widget: null, renderer: null,
toBeRendered: true, onTop: false, visible: true, containerData: null,
accessibilityPhrase: null) (label: Twitter, iconURI: null, tooltip:
null, context: null, variables: null)
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2013-03-13 13:38:03.952
!STACK 0
at
org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.showTab(LazyStackRenderer.java:156)
at
org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:109)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl@192ad7e
(elementId: de.icc.perspectiveStack, tags: [], contributorURI:
platform:/plugin/de.icc.application) (widget: Composite {}, renderer:
org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer@12f6fe9,
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Re: Problems with contributing a perspective via fragment [message #1018857 is a reply to message #1018241] |
Thu, 14 March 2013 11:19   |
I recently encountered a similar problem. I'm also looking for a solution. Here are my observations:
1. When I contribute a perspective via fragment it is shown, but whenever I select it, close an application and start it again, the perspective isn't selected. I have to reselect it manually. In console it throws a problem with "org.eclipse.e4.ui.workbench.swt" plugin.
2. To overcome it, I created empty perspectives in the application model and then my fragments are contributing to them. The processor just checks if the perspective has children. If has, then it is added to the menu.
But contributing parts to perspective with a fragment might have more problems. Later I moved all parts to sharedElements to use placeholders (why they don't see shared elements from application model?), so that I could open any part in any perspective. Now I can see all perspectives with their children, but the perspectives, to which I contributed placeholders from fragments, don't remember their state after reloading the application. Only the main perspective, created in the application model, restores everything as should.
To investigate it, I created another processor that runs before merging fragments with the application model. What's interesting:
- before merging all perspectives remember their state from previous session,
- after merging the perspectives are restored to the state as declared in the fragment model.
It shouldn't be that way, should it?
So I'm just thinking, it those problems aren't connected. Perhaps adding whole perspectives from a fragment doesn't work, because something odd is going on during merging?
I also found that placeholders that are added to perspectives during the run, loses their references after reloading the application. All contributions to the sharedElements area is OK, just the added placeholders have bull reference which forces me to manually check every placeholder and repair the reference in the processor. Can it be that there is something wrong with the *e4.ui.workbench.swt plugin?
I would be grateful for any advices.
Mateusz
Re: Problems with contributing a perspective via fragment [message #1019794 is a reply to message #1018241] |
Sat, 16 March 2013 13:37   |
When there is a need, there is a way.
I managed to solve the problem with contributing perspectives and they persist their state. To do so:
a) create a processor that runs after fragments,
b) after merging a perspective expand its ID by, e.g., ".merged",
c) when checking perspectives in the loop:
- if current perspective's ID contains "merged", leave it,
- if there is a perspective, which ID is the current perspective's ID expanded by "merged", save the current perspective in the list toBeDeleted,
- if nothing above is true, merge the perspective
d) delete perspectives from toBeDeleted list
Moreover, if we want to reset the perspective (or remerge it), we simply have to remove the ".merged" part from its ID (I haven't added this functionality, but should be easy).
Nevertheless, I look forward for solution to this merging issue.
Mateusz
edit: I believe that in the similar way it is possible to solve a problem, when fragments are not contributing whole perspective, but just some parts to part stack/stashes.
[Updated on: Sat, 16 March 2013 13:39] by Moderator
Current Time: Sun Jul 20 16:34:04 EDT 2025
Powered by FUDForum. Page generated in 0.04592 seconds
