ImportURI for ecore models and Xbase scoping [message #1017981] |
Tue, 12 March 2013 18:40  |
Dear Xtext users,
I would like to design a small Xbase based DSL to describe adapters working at the
metamodel level. The idea is to describe how to bind EStructuralFeature/EClass of a given EPackage
(the adapted one) to another EPackage (the target).
To achieve this, I would need to import existing ecore files (through importURI) but also
use XBase to describe possible adaptation code when the mapping is not straighforward.
Right now, I am completely lost with Scoping/Linking when dealing with cross-references to
external objects from my Ecore files.
My Xtext grammar looks like this :
grammar fr.irisa.cairn.VisitGen with org.eclipse.xtext.xbase.Xbase
generate visitGen "http://www.irisa.fr/cairn/VisitGen"
import "http://www.eclipse.org/xtext/common/JavaVMTypes" as types
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
// JGraphT java subgraph isomoprhism http://code.google.com/p/fasubis/
TopLevel:
(imports+=Import)* adapters+=ModelAdapter+ ;
Import: 'use' importURI=STRING;
ModelAdapter:
'adapt' src=[ecore::EPackage|ID] 'to' target=[ecore::EPackage|ID] '{'
classBinders+=ClassBinder*
ClassBinder:
'bind' src=[ecore::EClass|ID] 'to' target=[ecore::EClass|ID] '{'
(featureBinders+=FeatureBinder ';')*
FeatureBinder:
'map' src=[ecore::EStructuralFeature|ID] 'to' target=[ecore::EStructuralFeature|ID]
('as' adapter=XExpression)?;
My Xtext mwe2 workflow (part of):
// scoping and exporting API
fragment = scoping.ImportURIScopingFragment {}
fragment = exporting.SimpleNamesFragment {}
// fragment = scoping.ImportNamespacesScopingFragment {}
// fragment = exporting.QualifiedNamesFragment {}
fragment = builder.BuilderIntegrationFragment {}
Here are my questions :
I understand the XBase uses its own customized scope/linking mechanism, and that my Ecore object are hence invisible
since they are not jvm objects. After searching around I found the following solution
(http://www.eclipse.org/forums/index.php/mv/msg/379428/918699/) which I tried with no success.
The strang thing is that I get different type of error depending whether I run the editor aftre exporting it in my main
eclipse dropin folder or run-it as a Eclipse application.
In the first case I get observe
org.eclipse.xtext.linking.lazy.LazyLinkingResource - resolution of uriFragment 'xtextLink_::0.1.0.2.0.2.0::0::/3' failed
In the second case I get
Caused by: java.lang.IllegalStateException: No IResourceServiceProvider found in registry for uri
platform:/resource/project/model/Target.ecore at
org.eclipse.xtext.scoping.impl.LoadOnDemandResourceDescriptions.getResourceDescription(LoadOnDemandResourceDescriptions.java:70)
at
org.eclipse.xtext.scoping.impl.ImportUriGlobalScopeProvider.createLazyResourceScope(ImportUriGlobalScopeProvider.java:104)
I must admit that I am a bit lost, can someone give me a few advices on the proper way for handling this ?
Thanks in advance,
Steven
Re: ImportURI for ecore models and Xbase scoping [message #1019006 is a reply to message #1017981] |
Thu, 14 March 2013 18:05  |
Hi again,
I spent the last two days trying to understand the problem and solve it without any
success.
Some hint would really be welcome !
Steven
Le 12/03/2013 23:40, Steven Derrien a écrit :
> Dear Xtext users,
> TopLevel:
> ModelAdapter:
> ClassBinder:
> FeatureBinder:
> at
> Thanks in advance,
> Regards,
> Steven
FUDForum. Page generated in 0.08145 seconds
