Home » Archived » Sapphire » Monitoring adds/removes to a ModelElementList
Monitoring adds/removes to a ModelElementList [message #1017470] Mon, 11 March 2013 18:15 Go to next message
I have the feeling this has a simple answer, but I'm wondering what the recommended approach is for monitoring when elements are added to/removed from a ListProperty.
My scenario is a Sapphire editor linked to a View built using Worldwind, and used to edit a list of geolocated objects. Each object has a linked graphic within the Worldwind view. Currently these graphics are created/populated when the Sapphire editor is opened, and disposed when it closes, but naturally I would like to add them on-the-fly as the user adds a new ModelElement to the list (and, conversely, remove them when an element is removed from the list).
I'm unsure within the hierarchy of Sapphire events and listeners which would be most appropriate for this. In particular, I need to make sure any new ModelElement is fully initialized before I try to retrieve it (I have InitialValueServices on several of the properties).
Any suggestions would be greatly appreciated.
Re: Monitoring adds/removes to a ModelElementList [message #1017480 is a reply to message #1017470] Mon, 11 March 2013 18:49 Go to previous messageGo to next message
For a list property, PropertyContentEvent will fire when list entries are added, deleted or rearranged. This event will fire before nested properties are initialized. Initialization of those property will trigger PropertyContentEvent on those properties.
- Konstantin
[Updated on: Mon, 11 March 2013 18:55] by Moderator
Re: Monitoring adds/removes to a ModelElementList [message #1017787 is a reply to message #1017480] Tue, 12 March 2013 10:40 Go to previous messageGo to next message
Thanks. That raises another question: if I register a Listener for PropertyContentEvents on the list property, and retrieve the nested properties, is there a way to "force" the initialization of those properties?
Re: Monitoring adds/removes to a ModelElementList [message #1017799 is a reply to message #1017787] Tue, 12 March 2013 11:01 Go to previous messageGo to next message
You could try calling element.initialize(), but keep in mind that the initialization will happen again after your listener exits and control returns to the list. A better way to do this is to write your listener to not be dependent on catching the model immediately after initialization. If you listen on PropertyContentEvents on the nested value properties, you will see when they are initialized and be able to update whatever state your listener is building.
- Konstantin
Re: Monitoring adds/removes to a ModelElementList [message #1017840 is a reply to message #1017799] Tue, 12 March 2013 12:14 Go to previous message
Thanks!
Previous Topic:Proper use of/examples for InitialValueService?
Next Topic:potential workaround for startup speed issue
Current Time: Sun Jul 20 13:07:04 EDT 2025
Powered by FUDForum. Page generated in 0.05636 seconds
