Home » Modeling » GMF (Graphical Modeling Framework) » How Can I Enable Delete From Diagram Button
How Can I Enable Delete From Diagram Button [message #1016978] Fri, 08 March 2013 07:45 Go to next message
Hi all,
First of all i m new to GMF.
Problem;
When i create diagram from gmf always delete from diagram button is disabled.
So what i must do, i need these button cause of working large models. Anyone can help
me ?
Re: How Can I Enable Delete From Diagram Button [message #1017004 is a reply to message #1016978] Fri, 08 March 2013 09:38 Go to previous messageGo to next message
that delete form diagram is disabled may be an indication that your diagram has
canonical behavior.
Andreas
Re: How Can I Enable Delete From Diagram Button [message #1017008 is a reply to message #1017004] Fri, 08 March 2013 09:51 Go to previous messageGo to next message
In the xxEditPart.java file found in the path
src\org\xx\diagram\edit\parts,
Comment the following lines
//installEditPolicy(
// EditPolicyRoles.CANONICAL_ROLE,
//new xx.diagram.edit.policies.xxCanonicalEditPolicy());
I am not sure if this is the right way to do,but it worked. But when i was delete
element on my diagram i cant reload element again Smile. I Confused just i need
when i want to delete element on diagram i can delete but later i can be reload this
too. ( Because i need views of my Model ). But i cant reload that element again
Re: How Can I Enable Delete From Diagram Button [message #1017102 is a reply to message #1017008] Sat, 09 March 2013 04:50 Go to previous messageGo to next message
so what you want is just to hide/show elements and not delete them. Please see: http://wiki.eclipse.org/GMF_Newsgroup_Q_and_A#How_can_I_hide_an_edge_on_a_diagram.3F
regards,
Re: How Can I Enable Delete From Diagram Button [message #1017226 is a reply to message #1017102] Mon, 11 March 2013 04:58 Go to previous messageGo to next message
Yeah Hide and show fine for me but when i hide more then 1 element on my model
i cant find list of hide elements to select one for Show. Only posibbleties is Show
all. So how can i show just one element from Hided more than 1 model elements?
Regards.
Re: How Can I Enable Delete From Diagram Button [message #1017243 is a reply to message #1017226] Mon, 11 March 2013 05:41 Go to previous messageGo to next message
I think that you might find some ideas in Mylyn/Modeling bridge: http://wiki.eclipse.org/Mylyn/Modeling_Bridge
regards,
Re: How Can I Enable Delete From Diagram Button [message #1176713 is a reply to message #1017243] Fri, 08 November 2013 09:02 Go to previous message
when i remove canonical behavior, my diagram and model can't be synchronized when i create element from model it don't appair on diagram ?
I can't find any solution
Previous Topic:Extend External Label representation and only show it by hovering the mouse
Next Topic:ModelingAssistantProvider
Current Time: Sun Jul 20 09:01:55 EDT 2025
Powered by FUDForum. Page generated in 0.04213 seconds
