Home » Archived » BIRT » Layout Table Complex
Layout Table Complex [message #1016505] Wed, 06 March 2013 12:05 Go to next message
i have to design a report like this layout:
https://dl.dropbox.com/u/47586998/layout%20A.bmp
i do this:
i create 2 groups, the first for process, the second for Level and then i insert all in the detail.
My idea is to set the rowspan of the process and level based on the value; but the rowSpan doesn't work, so my result is this:
https://dl.dropbox.com/u/47586998/layout_B.bmp
How can I get the same result?
Thanks in advance
Re: Layout Table Complex [message #1016537 is a reply to message #1016505] Wed, 06 March 2013 14:50 Go to previous messageGo to next message
What you're looking for looks like a crosstab's row dimension area. You might try using a crosstab.
Re: Layout Table Complex [message #1016561 is a reply to message #1016537] Wed, 06 March 2013 17:42 Go to previous messageGo to next message
Hi Michel,
i try use a crosstab, but seems to have a non-linear development of data, my development instead is a simple table layout with the difference that the first column and the second are groups, and the values ​​should have the rowspan instead of repetition.
It's possible to do this?
Re: Layout Table Complex [message #1016607 is a reply to message #1016505] Thu, 07 March 2013 01:34 Go to previous messageGo to next message
Take a look at this report. It uses your data in a csv and has two groups on a table, then utilizes the drop feature on the group element cells and also has the vertical alignment set to middle. Hope this helps.
icon14.gif  Re: Layout Table Complex [message #1016692 is a reply to message #1016607] Thu, 07 March 2013 06:26 Go to previous messageGo to next message
Is just what I wanted!!!
Thanks a lot
Re: Layout Table Complex [message #1016759 is a reply to message #1016692] Thu, 07 March 2013 10:42 Go to previous message
You're welcome!
Previous Topic:PDF Generation, dynamic Text in Cell
Next Topic:HTML Emitter - How to get the axis description of the charts
Current Time: Sat Jul 19 08:30:40 EDT 2025
Powered by FUDForum. Page generated in 0.08362 seconds
